emma under construction(my hatch build)
Old 02-06-2009, 07:08 PM
1xfastxhatch's Avatar
Default emma under construction(my hatch build)
got this car for my 17 birthday in june of 07. did the normal wheels tires and suspension upgrades shortly after. i then found a 92 LS teg for 250 so i bought it for the motor trans and other swapable parts. the first winter i had the car i noticed some bondo work startin to pop. in feb of 08 i started tearin in to the hatch. for the record this is my first project car learning everything as i go thanks to honda-tech and some helpful friends.so on with the parts list and pics.
*car*
1995 cx hatch
*motor*
b18a1
ctr pistons
stock rods w/arp bolts
balanced rotating assembly
arp main and head studs
cometic HG
crower 404 cams
crower dual springs w/ ti retainers
3 angle valve job
mild p an p
ge cam gears
hondata IM gasket
blox IM
blox TB 68mm
presicion turbo 440 injectors
b and m FPR
hasport mounts
*tranny*
cable YS-1
LSD stage2 6 puck clutch
hasport cable/hydro conversion
*suspension*
tokico illumina
tokico springs
energy suspension bushings
skunk2 camber kits f/r
skunk2 LCA
homemade adjustable toe links
*brakes*
*front*
fast brakes 11" adapters
integra calipers
axis ultimate pads
vw corrado rotors
ss lines
*rear*
disk conversion
ss lines
now the pics
d15b8 out
11" big brakes
rear disk conversion
motor back from the machine shop
motor ready to go in
motor in bay painted and wire tucked
stay posted will update as progress continues
Old 02-07-2009, 03:47 AM
namewasdallas's Avatar
Default Re: emma under construction(my hatch build)
Looking good, I'm becoming a bigger fan every day of the nonvtec motors, Liken the setup keep up the good work.
Old 02-07-2009, 03:55 AM
gibsanez's Avatar
You're crazy, I wouldn't even CONSIDER touching that body work. Good job.
Old 02-07-2009, 04:35 AM
All Motor Mentor
00Red_SiR's Avatar
This is in the wrong forum, it should have been posted here: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/
The ALL MOTOR Forum is supposed to be a TECHNICAL forum, which this thread clearly is not.
Old 02-08-2009, 11:25 AM
whats this sensor and can i eliminate it from my harness
when i was building my harness i didnt know what it was so i just kept it
Old 02-08-2009, 11:44 AM
93egSLEEPER's Avatar
hat has to do woth you evap system i beleive. i took mine off but kept the plug on my harness just in case i ever needed it. one less thing to worry about so delete it
Old 02-08-2009, 12:19 PM
trustdestruction's Avatar
great work man
looks good
Old 02-08-2009, 01:11 PM
starion88esir's Avatar
Damn good to see someone willing to go to the proper length to repair rusted panels. Damn good for a first timer. You should do something about the rust on the underside of the car as well.
Old 02-08-2009, 05:09 PM
F20B-CX's Avatar
I approve. Death to rust.
Old 02-08-2009, 06:53 PM
i got rid of the rust underneath as well i just dont have pics of it
Old 02-08-2009, 07:19 PM
en00be's Avatar
looks good man
Old 02-10-2009, 07:47 AM
*UPDATE*
need to pull motor and tranny back out. when i went to put my axles in i discovered the tranny has bad diff bearings. so gonna rebuild the tranny whoknows what else i might find when i open it up
heres the pics of under car rust taken care of
Old 02-10-2009, 07:53 AM
kp
kp's Avatar
Can you post some pictures of your cable/hydro conversion on the tranny? I have to do the same thing and I've been curious about what kind of pieces are involved. Thanks.
Old 02-10-2009, 07:55 AM
jsant07's Avatar
nice work man....i just got my cx all patched up and painted i wish i had the means to do it myself keep it up
Old 02-10-2009, 03:35 PM
when i pull the motor this weekend ill take some pics for ya
thanks to everyone whos complimented my project
Old 02-10-2009, 03:51 PM
nemesis25's Avatar
Looks great. I'm impressed at the patch work. BTW which weld did you use, Mig or Tig? Also, for cutting what did you use?
Old 02-10-2009, 09:38 PM
i used a lincon 110v mig for the cutting i used a grinder with a cut off wheel
Old 02-11-2009, 08:26 AM
kp
kp's Avatar
That would be great if you could. Cheers.
Old 02-11-2009, 12:42 PM
91blackEF's Avatar
looks real good man i wish i had a shop to work in so i could get into my car to this extent all i have is the front street
Old 02-11-2009, 12:56 PM
punkinbeck's Avatar
nice work. Aren't those inner fenders a bitch?? I wish some body panel company would stamp those out. They'd sell the **** out of them.
Did you use the magnets out of an old set of speakers to hold the wheel arches in place ??
Old 02-11-2009, 01:24 PM
teamworxek9's Avatar
that was some bad *** rust.
Old 02-11-2009, 01:29 PM
sp00ledbseries's Avatar
DAMN good job man i though my hatch was bad when i got it
Old 02-11-2009, 02:12 PM
iliv2xlr8's Avatar
Good work!
Old 02-12-2009, 10:41 AM
kp
kp's Avatar
Try using old harddrive magnets. Those things are hella strong.
Old 02-19-2009, 06:50 AM
*UPDATE*
motor and tranny are back out gonna crack open the tranny soon to see if there is anything else bad other than diff bearings
heres the pics of the cable to hydro conversion that kp wanted
Quick Reply: emma under construction(my hatch build)
