Em1 wont start, no fuel
Old 11-16-2014, 04:01 PM
JdmRex805's Avatar
Default Em1 wont start, no fuel
I have a problem with my em1 not wanting to start. I recently rebuilt the motor have put about 180 miles and everything worked great. When i got off work one night i was pulling out of the parking lot and the car just died, no check engine light. It ended up starting right up and drove it home. Car sat for 2 days and when i went to start it up couldn't hear the fuel pump prime and car would not start. The IACV was also making clicking sound as soon as you put the ignition to ON (II) and the checking engine light would dimly flash rapidly along with the clicking. Tried to jump the connector to check for cel and it did the same.
I have checked grounds, tested main relay and used a know working one, tried different ecu, replaced the fuel pump. Checked and replaced fuse 44, 13, and 31. If I unplug the iacv and turn the ignition the clicking stops and the check engine doesn't dimly flash. The check engine light comes on for 2 sec and you can hear the fuel pump prime like it should but it still wont start. WHen I try and check for a cel the light doesn't come on the cluster at all.
What else can i try?
Old 11-16-2014, 04:15 PM
Former User's Avatar
Default Re: Em1 wont start, no fuel
^Contradicts idea of no fuel.
Is the CEL bulb burned out?
Is there spark at the plugs?
Old 11-16-2014, 04:30 PM
I never narc'd on nobody!
NotARaCist's Avatar
Rapid clicking and light flashing when starting...have you tried replacing the battery?
Old 11-16-2014, 05:08 PM
Hectic937's Avatar
Have you checked the ground to the thermostat housing?
I had a similar problem when swapping a motor in my EF.
Old 11-19-2014, 09:19 AM
JdmRex805's Avatar
when the iacv is plugged in the fuel pump doesn't prime, check engine light stays lightly dimmed and I hear a rapid clicking from the iacv. If I unplugged the iacv the fuel pump primes and check engine light turns on for 2seconds and goes off like it should when starting. Not getting any spark at the plugs. Tried a know working distributor, has new wires and plugs.
Old 11-19-2014, 09:20 AM
JdmRex805's Avatar
Getting 12 volts from battery but I did try another one
Old 11-19-2014, 09:21 AM
JdmRex805's Avatar
Yeah that's the first thing I checked. Cleaned up all the grounds.
Old 11-19-2014, 09:25 AM
12.0 V is a low battery.
Bone stock EM1 or mods (list them)?
Have you checked for swapped sensor connectors?
Old 11-19-2014, 09:26 AM
JdmRex805's Avatar
Check engine light bulb is not out because it does light on and off just cant check for cel jumping the service connector. Do obdb2b have blue wire on pin 8 for engine output speed?My harness doesn't have a wire to it. I beleive it gets signal from the ecu?
Old 11-19-2014, 11:54 AM
JdmRex805's Avatar
Get 12v from just battery I know it should be around 14v if car was running but that's my problem. I did check for swapped connectors
Old 11-19-2014, 12:00 PM
JdmRex805's Avatar
Bone stock em1
Old 11-19-2014, 12:08 PM
With the engine off, a 12.0V reading indicates a low battery . The reading should be ~12.5-12.9V.
Old 11-19-2014, 01:30 PM
Fish Twig
tony_2018's Avatar
^^what he said^^
Old 11-19-2014, 02:00 PM
JdmRex805's Avatar
Ok.. so imma charge the battery, I did try one off a different car though and it's doing the same thing not sure what voltage that has but it was from my brothers running car. Would low battery cause what seems like an electrical issue though? No spark, fuel pump not priming, iacv clicking and not being able to check cel by jumping service connector. Don't know what else to try?
Old 11-19-2014, 04:16 PM
92ehatch's Avatar
Ron asked if you had checked for swapped wires ie wrong place. Done connectors fit more than one place. You didn't answer that question.
It's super common and i believe can fry ecus
Old 11-19-2014, 04:22 PM
JdmRex805's Avatar
I wrote that I have checked for swapped wires. Checked the wire color on plugs and everything seems good. Car was running perfectly fine died on me once, drove it home car Sat for 2days and then it just gave me these problems I'm having
Old 11-19-2014, 04:25 PM
92ehatch's Avatar
My apologies
Old 11-20-2014, 01:56 PM
JdmRex805's Avatar
Anyone else have any ideas of what else I can check?
Old 11-20-2014, 04:51 PM
So what happened? Update your thread.
Old 11-20-2014, 05:23 PM
JdmRex805's Avatar
Not the battery either. My bro has an ek with gsr swap so I've been using **** off his to try and diagnose. We swapped batteries mine worked on his his didn't make a difference.
Ruggeh
31
01-10-2016 12:00 PM
jays35
06-17-2014 02:31 PM
olds1983
Honda Civic (2001 - 2005)
12-02-2012 06:34 PM
fryman
16
12-31-2008 07:56 AM
lazylegs15
09-14-2008 10:20 PM
Quick Reply: Em1 wont start, no fuel
