em1 oil change no oil in oil filter wtf
Old 11-19-2009, 11:38 PM
v8killaz's Avatar
Default em1 oil change no oil in oil filter wtf
so i was doing my oil change, no leaks no oil burning just a reg oil change. the car was jacked up quite a bit. then i drained the oil through the bolt till it stopped coming out. then i took off the oil filter by hand and their was almost no oil in it. i flipped it and no oil came out, after i let it sit, very little came out like a tablespoon or 2
but oil pressure is good 80-90psi i think
is this normal, i do alot of oil changed but first one in this car. and ive never had something like this usually yhr filter is full of oil
none spilled from the male end on the filter or the oil filter when i removed it.
am i overexagerating or could this be a potential problem in the future
v8killaz's Avatar
Default Re: em1 oil change no oil in oil filter wtf
heres another thred i read before posting this
https://honda-tech.com/forums/tech-misc-15/no-oil-oil-filter-help-2678872/#post40620259
Old 11-20-2009, 06:18 AM
v8killaz's Avatar
changed oil
car runs great vtec engages fine.
oil pressure at like 60 idle and goes up to 90+ when revving
Old 11-20-2009, 08:51 AM
I'm not Rick!
rick_rabies's Avatar
Originally Posted by v8killaz
changed oil
thats alot of pressure. check your oil pickup inside (if you remove the oil pan)
Old 11-20-2009, 09:16 AM
Jimster480's Avatar
what should it be? In my Y8/Z6 setup, its about 60 idling 80ish when accelerating when i first turn it on. Eventually it gets down to about 12PSI per 1000RPM's, but usually hovers around 18-25 on idle. And goes to 60-70 @ redline.
Old 11-20-2009, 09:27 AM
I'm not Rick!
i think all the guages ive seen say about 20-30 then 40-50 in higher rpms.
that is for gsr motor though. about 4 dif gsr motors
Old 11-20-2009, 09:30 AM
I'm not Rick!
at least at those levels have some sort of good crankcase breathing.
Old 11-20-2009, 09:46 AM
Jimster480's Avatar
oh well ok, then my pressures are fine, i was just worried that they might be low lol
Old 11-20-2009, 03:21 PM
v8killaz's Avatar
my autometer gauge hooked up to the pressure sedning unit goes all the way up to 90+ WHEN I floor it.
J.nguyen
10-14-2006 06:04 AM
Tim Martin
02-18-2006 01:06 PM
WiCkeDReX
12-09-2004 12:26 AM
2005 TSX
11-04-2002 08:41 PM
Quick Reply: em1 oil change no oil in oil filter wtf
