EM1 AC question - Honda-Tech
EM1 AC question
Old 03-19-2017, 07:27 AM   #1
Default EM1 AC question
I just got an EM1 and the entire AC was removed except blower motor. I know the em1 uses a different compressor and different lines. Could I just place the lines and compressor with a regular ek ac system? When I've looked on some honda parts sites some of the lines were discontinued and I need the entire system. I figured it would be easier and cheaper to take out the entire system at a junkyard if I can use a d series. The motor going in the car will be a b18c so I know I would have to get a bracket to mount. Would not be getting mounted to a b16 if that matters.
maddaug is offline   Reply With Quote
Can I bypass the ac compressor on a 2007 Honda Odyssey? Mike Beachy Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 1 10-27-2016 09:06 AM
the difference between the b-series and d-series a/c system! philosofy1 Honda Civic / Del Sol (1992 - 2000) 23 09-06-2014 06:14 PM
Proper R12 to R134a Conversion (Sanden) 90_Si Honda CRX / EF Civic (1988 - 1991) 45 07-07-2013 12:43 PM
= H23a1 A/C system removal? Belt question. preludebbduce Honda Prelude 8 09-09-2006 11:35 AM
A/C question, Help ASAP, its hot here. stehigs321 Honda Civic / Del Sol (1992 - 2000) 5 07-10-2003 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
