EK with Vtech
EK with Vtech
a person told me that if you want too swap a b18cr that it would be easyier if it already has Vtech my question is dos any EK come with Vtech
Guest
Posts: n/a
Re: EK with Vtech (dirtyapes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyapes »</TD></TR><TR><TD CLASS="quote">a person told me that if you want too swap a b18cr that it would be easyier if it already has Vtech my question is dos any EK come with Vtech</TD></TR></TABLE>
EK4
Ek9
EK4
Ek9
so either way when i do the swap ita gonna be hella hard with the wirring cause they said it would be easier if you already have vtec
Re: EK with Vtech (diearzte2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 »</TD></TR><TR><TD CLASS="quote">
EK4
Ek9</TD></TR></TABLE>
I don't know where diearzte is going with that, both of those cars are only available in Japan Whatever EK hatchback you are going to get you have to wire it for VTEC.
EK4
lets start with:
what car do you have?
Everyone always says ek for all 96-00, whether theyre a hatchback or not.
Actually in the us there were no 'ek's they were all ej.
haha! Doh! Swaps nowadays are easy than in the past. If got some cash you can make it happen. Money solves all you vtec needs.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">lets start with:
Actually in the us there were no 'ek's they were all ej.</TD></TR></TABLE>
I don't mind when people call a 96-00 Hatchback an 'EK' but I can't ******* stand it when I click on a thread titiled "Pics of my EK" and all I see is a damn coupe. Coupe = EJ; Hatch = EK please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyapes »</TD></TR><TR><TD CLASS="quote">i have a 98 civic hatchback(stock ) so u can only get ek4's in japan? so on a level of 1-10 how hard is the swap gonna be</TD></TR></TABLE>
Depends on how mechanically inclined/how much mechanic work you've done. It's no walk in the park, but it's really not nearly as tough as say, rebuilding a transmission.
Unbolt the old stuff and rebolt the new in. Run a couple of lines for VTEC and be done with it.
Re: EK with Vtech (veggiemaster)
well first i know i can swap the stock motor out(common sence) the only thing that im gonna need help on is how to put the mounting brackets from the si and i guess it shhould be easy after that just matching stuff with stuff. im gonna be buying a digital camera if i run into any problems. so the wiring i just run through the fire wall and hook it up well i should be starting this project in the next month so thanks. also is there anyone close to northern cali that if i hae anyproblems they could just try stopping by and helping. thnks
you should probably use the money you were gonna use on the camera and use it to pay someone to put that motor in. Less headache man.
As long as the motor your putting in the car has the OBD system your wiring problems should be very small. (an EK is OBD-2 so if your motor that your gonna swap is OBD-2 also then you should not have a great deal of problems.)
