ek main relay problem
Old 12-24-2007, 10:25 AM
Killercarbine's Avatar
Default ek main relay problem
My friend and I just finished swapping in a odd1 b16 in his 96 dx, when we first tried to start it we had no fuel so we traced it to the main relay. We have tested the ground and the 12 volt switched and constant, if we bypass the relay it runs fine but if we replace the relay the fuel pump doesn't turn on any ideas?
Old 12-24-2007, 10:29 AM
IMALLSLO's Avatar
Default Re: ek main relay problem (Killercarbine)
If it worked before,im sure its gonna work fine after. Main relays dont go bad because you swapped over a motor. Id look in another direction. Alarm system?
Old 12-24-2007, 10:31 AM
Default Re: ek main relay problem (IMALLSLO)
no alarm, he bought the car as a slightly abused shell
Old 12-24-2007, 11:41 AM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killercarbine &raquo;</TD></TR><TR><TD CLASS="quote">no alarm, he bought the car as a slightly abused shell</TD></TR></TABLE>
Got it. Then continue troubleshooting.
If you bypass Blu/wht to Yellow/grn then of course you will have a fuel pump turn on. I dont think its the Main relay. It may be an input from the PCM
Old 12-24-2007, 11:48 AM
thanks, we used the dx harness with a jumper obd2a - obd1 would that affect it?
Modified by Killercarbine at 1:03 PM 12/24/2007
Old 12-24-2007, 12:48 PM
IIXtremeHansen's Avatar
did you plug the big green one thats around the ecu? that causes your car not to start and prime. the plug thats outside the ecu.
ckirso
03-18-2013 08:08 AM
EARLdaSQUIRREL
Audio / Security / Video
07-16-2008 11:12 AM
justinsouza
03-31-2007 07:23 AM
Magick211
11-21-2004 03:21 PM
drew2
04-29-2004 05:02 AM
Quick Reply: ek main relay problem
