EK Hatch Project Build - Stauffer Garage
Old 01-12-2017, 06:29 AM
  #26
4drtegra's Avatar
Default Re: EK Hatch Project Build - Stauffer Garage
Originally Posted by eghatch9295
i have PIC selects. worth the wait.
Did you call and place and order and get a lead time? I just have never seen the blog or site show my car in stock
Old 01-12-2017, 06:35 AM
  #27
Fish Twig
tony_2018's Avatar
Hmm...they only selling the rear setup. I wonder whats up...
Old 01-12-2017, 06:37 AM
  #28
Fish Twig
tony_2018's Avatar
You can always email too. They are good at responding via emails. The timeframe to me was pretty decent. I've had to re-order some bushings from them because of the ones I fudged on and they were able to get it to me in a good timeframe given the bad weather lately.
edit: awesome quality videos btw. Keep it going. This is a different style of build threads and hopefully others are capable of doing the same.
Old 01-12-2017, 10:16 AM
  #29
4drtegra's Avatar
c
Old 01-12-2017, 05:54 PM
  #30
Fish Twig
tony_2018's Avatar
Well...they will be on hiatus...chinese new year...sorry bud...
Hey man as long as your videos are HD/HQ I'm fine with it. I just get sick and tired of people posting videos like they used and old school camcorder. Freakin 2017....
Old 01-18-2017, 05:20 AM
  #31
4drtegra's Avatar
c
Old 01-18-2017, 05:45 AM
  #32
Fish Twig
tony_2018's Avatar
Interesting, I've never had that problem when removing the subframe. Was it rusted to ****?
I just finished up on my sisters db7 on all bushings, can't wait to take it out on for a spin.
Yes the proportion valve is needed.
Gather the cost of rebuilding (oem vs aftermarket rebuild) vs buying from rockauto. Do you have time to do the rebuild?
Old 01-18-2017, 06:10 AM
  #33
talks to himself
CX-Adam's Avatar
I rebuilt my calipers and I'm totally incompetent. That being said, it's not the easiest process in the world. Getting the piston seals correct is kind of a PITA. But, if you've the time and it saves money, do it. It's kind of fun to learn.
Old 01-18-2017, 09:41 AM
  #34
4drtegra's Avatar
c
Old 01-18-2017, 02:25 PM
  #35
Fish Twig
tony_2018's Avatar
I had the lca's pressed out by a shop, but I started taking care of the bushings myself with a balljoint kit from Autozone. I needed some washers and some deep sockets and I was on the way to pressing my own bushings. I'll need to size up the lca bushings so I can try them out when I start on my own civic. It was a good feeling to do it myself. Man this db7 gonna feel real nice on the road.
Old 01-19-2017, 11:30 AM
  #36
4drtegra's Avatar
c
Old 01-19-2017, 01:11 PM
  #37
civic402lx's Avatar
I rebuild the caliper on my 98 civic sedan with OEM kit. Pretty pleased with it. Not very hard. I used those stirring stick u get at starbuck to push the seal down into the groove. Have a sanding wheel around help quite a bit. The piston had rust build up around the base of the seal. Cleaning those rust up is much easier with a sanding wheel. I didn't fully disassemble the caliper. Only the piston and the wire ring that hold the seal in. Then I clean out the inside of the caliper, then shove some rag inside it. While I clean, with a wire brush, the body. Air blow the rust off. Then put everything back. No more leak. Brakes is nice and firm.
Good luck with your project. I do enjoy the vids. Keep up the good work.
Old 01-27-2017, 10:42 AM
  #38
4drtegra's Avatar
c
Old 01-27-2017, 10:50 AM
  #39
talks to himself
CX-Adam's Avatar
Cool shots. There's a photography thread in GDD if you're into photography. Be forewarned, though. GDD is not for people with thin skin.
Old 01-27-2017, 10:56 AM
  #40
4drtegra's Avatar
Lol I'll keep that in mind!
Old 01-27-2017, 04:08 PM
  #41
talks to himself
CX-Adam's Avatar
P.S. Sub'd to your YouTube Channel.
I might be interested in the Engine Harness.
Old 01-27-2017, 06:16 PM
  #42
4drtegra's Avatar
Sweet deal! The DX harness?
Old 02-13-2017, 08:57 AM
  #43
GreatWave's Avatar
Stumbled across your part out on the Columbus CL. I'm interested in a couple things, PM me!
Old 02-14-2017, 09:30 PM
  #44
Renntech's Avatar
Awesome post and videos!
Old 02-17-2017, 03:24 AM
  #45
4drtegra's Avatar
c
Old 09-19-2017, 05:58 AM
  #46
4drtegra's Avatar
c
Old 09-19-2017, 07:54 AM
  #47
mattvivsound's Avatar
Good news is I have been busy breaking down the Integra further and have the entire interior pulled. Every nut, bolt, wire is removed and now the exterior is getting the same treatment. There is so much money in individual parts on ebay... its crazy. Last night while trying to drop the entire subframe with front suspension, I shattered a 19mm socket with a 5ft breaker bar... so an impact socket is necessary when I go back to battle with the undercarriage. The plan is to swap over all of the integra suspension, knuckles, brakes and subframe (utilize GSR sway, steering rack converted to manual and the T-bracket) which will work perfectly if I can get the PIC bushing set. I'll be restoring the suspension components with those bushings, fresh coat of paint prior to reinstalling so they are just like new when they go on the civic hatch.
I've heard multiple responses on the necessity but I need some advice on rebuilding the GSR calipers or just buying new from Rockauto and sending the old ones in as cores. Thoughts? Also, the brake master cylinder, booster will need to be swapped over and I am curious if the distribution block from the civic DX will work or the GSR...
I'm in the works of getting all the parts needed to add the Integra brakes to my '99 Civic DX Hatch. From what I have read, the brake proportioning valve is the same for all Hatches and EM1. My plan is to use the 15/16" master cylinder out of a Civic EX w/ ABS with current brake booster.
Also note, somewhere in the 96-00 the brake systems changed up: the Master Cylinder went from angled mounting points to horizontal AND the Pro Valve went from an "I" to a "K" style.
Cfisch619
03-19-2016 07:33 PM
H22hatchin
12-26-2011 01:13 PM
MattZ28
06-24-2008 06:05 AM
mike_belben@yahoo.com
06-20-2007 06:00 AM
mikeyz
05-03-2006 03:59 PM
Quick Reply: EK Hatch Project Build - Stauffer Garage
