EK driver window
Old 06-01-2009, 05:34 PM
liljohn850's Avatar
Default EK driver window
ok, so i hear that this is a common problem. i have manual windows. whats a good fix? the window comes off the track all the time when i roll the window down or up all the way
Old 06-01-2009, 05:43 PM
fastrxu's Avatar
Default Re: EK driver window
white lithium grease spray
put it back in the track; and spray some in there every couple months
it is a lubricant, and also waterproofs so make sure you get white lithium grease not wd40
Old 06-01-2009, 05:44 PM
Crazy Honda Guy
Deetz's Avatar
It's common alright. The fix......by a new oem regulator, the are now improved from the original.
Old 06-01-2009, 05:45 PM
liljohn850's Avatar
how crazy of a swap would it be to go to power windows?
Old 06-01-2009, 05:49 PM
jdmpoweredsol419's Avatar
u wud need to chk if u have the harness connector for the power windows..u shud hav it tho. ..not to hard tho
Old 06-01-2009, 05:52 PM
liljohn850's Avatar
where would i find that connection?
Old 06-01-2009, 05:59 PM
i havent had an EK for a while, but if my memory serves me correctly, it should be behind the driver kick pannel close to wher the door regulator is.
Old 06-02-2009, 06:23 AM
Kista20's Avatar
power windows have the same problems as well. My drivers side has come off track twice. The first time I just fixed it and put it back together like it was but then it came off again a longtime later but this time I did lube it up real good. If I ever have to do it again I'm going to use a new regulator.
Old 06-02-2009, 06:25 AM
99JDMHATCH's Avatar
yep just get what i have si doors equals power windows. Haven't had a problem with them since.
Old 06-02-2009, 10:59 PM
fastrxu's Avatar
I put power windows/locks/mirrors on my hatch that came manual windows.
It happens on both. The lithium grease only cost $2.59 it beats buying a whole new regulator. Plus in the install of a new regulator you'll probably make the misalignment worse.
When I did my swap I put brand new power window regulators, and still have this problem from time to time.
I recommend realigning it really good and the lube.
Old 06-03-2009, 07:00 AM
jdmztrane's Avatar
Don't go and buy a new regulator first. Go and buy a new window guide. The majority of the problems start there because the rubber rots or gets stuck in one position and binds up the window, causing you to force it out of alignment. This is also the cheaper route. If you go online to [link]www.majestichonda.com[/link] and order your window guide, it will cost you about $25-$30. Then, if that doesn't solve it, you may have to buy a new regulator.
All this was part of trial and error for me, as well as reading a lot of stuff on the internet and talking to a few Honda mechanics at different dealerships.
Old 06-03-2009, 04:17 PM
skodi's Avatar
easy fix: dont go all the way down with the window(ever), and never slam the door with it open
Old 06-03-2009, 04:31 PM
FearTheH's Avatar
the driver side is going to be common on any car, just due to the fact that its constantly used...in turn means what? more wear and tear. definitely agreeing with white lithium grease, make sure your track isnt bent, then put the window back in and grease it.
Old 06-03-2009, 04:49 PM
H-T White Ops
NOFX's Avatar
Silicone spray is actually the recommended lubricant for the windows IIRC. I know it's what I use. White lithium grease can eat away at rubber parts.
First, you'll want to see if someone else can help you with this. It's nice to have someone else to grab the glass if need be.
Front Door - 4 Door:
Door Panel Replacement
Outer Handle Replacement
Latch Replacement / Glass/Regulator Replacement
2 / 3 Door
Glass Adjustment
Glass Adjustment (cont'd)
Old 06-04-2009, 02:36 AM
fastrxu's Avatar
[QUOTE=NOFX;38774724]Silicone spray is actually the recommended lubricant for the windows IIRC. I know it's what I use. White lithium grease can eat away at rubber parts.
Dude you're totally right. That's what I MEANT to say. I just happened to have lithium grease in the garage and named that off the top of my head. But it's the silicone spray you want.
Old 06-12-2009, 10:12 PM
n/ahonda97's Avatar
this has actually been a pain in my a%% b4,i thought i had it solved 3 yrs ago, but then 2 days ago it happened agian.when it first happend i did the silicone,it worked for a short time then i moved the bolt hole(that is behind the speaker pod) over about 1/4" closer and it was great for a long time,but it came back to show its UGLY head.this is probably my biggest headache with my car.(power winows 2)
mreed
16
03-21-2012 12:26 PM
bleedblue94
16
11-25-2006 09:04 PM
jayare05
14
12-12-2004 11:50 AM
murmur9
12
11-20-2004 09:27 PM
StRacer
07-15-2004 04:44 PM
Quick Reply: EK driver window
