EG window problems HELP
so i have a 95 cx eg and the windows are manual and they get hard to roll down once they get about halfway down and also dont go up evenly the drivers side is worse than the passenger but any hints on making them roll smoothly?
Re: EG window problems HELP
you can try taking off the door panel and putting some grease on the gears and on the rollers towards the bottom, worked well for mine. Also if your windows do not line up they probably need adjusted.
i did take off the panels, do you recomend grease or som WD-40? and if its not aligned rite how do i fix that? ha im kinda new to most of this stuff
myflyintegra
01-14-2009 02:21 PM
hydroflip
05-02-2002 06:08 AM
