what would cause my back tire to wear on the inside?
Old 03-16-2010, 06:37 PM
724chris's Avatar
Default what would cause my back tire to wear on the inside?
i just got a allignment and replaced my struts and its still doing it.. im guesssing a bad trailing arm bushing?
Old 03-16-2010, 07:27 PM
redeg666's Avatar
Default Re: what would cause my back tire to wear on the inside?
the alignment guy should be able to tell you why
Old 03-16-2010, 07:38 PM
ej8coupegsr's Avatar
sounds like camber wear.. what type of suspension you runnin?
Old 03-16-2010, 08:19 PM
alphalanos's Avatar
irrelevant. only thing that can cause this is bent parts, or bad alignment. camber is not a major tire killer, toe is.
Old 03-16-2010, 10:02 PM
turnsignalandy's Avatar
is it even possible to adjust toe on 92-00 rear suspension? sounds like bent parts
Old 03-16-2010, 10:12 PM
boxeocampeon's Avatar
yeah but you should get even wear with a good toe alignment
Old 03-17-2010, 01:20 AM
Acuronda_SloTeg's Avatar
yes it can be aligned, the dillweed alignment guy probably didnt notice the toe ends right in front of the gas tank under the back seat area of the car. also check for bent parts like they said. and if you are rollin slammed, im not even gonna answer why its happenin
Old 03-17-2010, 03:33 AM
724chris's Avatar
nah its not slammed just on tein stechs. what could be bent in the back??
Old 03-17-2010, 11:27 AM
well he really didnt give to much info thats why i kinda went with that.. cuz i used to have the same problem with my hatch.. but as far as the bent part goes some of the more experienced dudes should know
Old 03-17-2010, 02:07 PM
camber takes a long time to show tire wear. Its toe that ****s **** up
Old 03-17-2010, 02:13 PM
Master Detailer
98civdx's Avatar
agreed
Old 03-17-2010, 09:32 PM
camber would be the camber arm that bolts to the inside of the wheel wheel. as far as toe goes, it could be a really jacked up lca or a slightly bent trailing arm. and even like i said before, the toe arm is a high thought suspect
VTECROAR96typeR
Suspension & Brakes
04-04-2010 10:11 AM
royalrebel
11-01-2008 07:50 PM
gsr98integra
11-08-2007 08:59 PM
Foxcow
06-30-2007 12:50 PM
EnjoyTheRideDC2
03-02-2006 04:05 AM
Quick Reply: what would cause my back tire to wear on the inside?
