eg passenger power window help!!
I've been having trouble getting my window to roll up, have to help it up and never dared to roll the window down all the way. Well today, a buddy of mine decided to roll it down all the way. Thanks buddy!! Now the window is stuck all the way down, I have removed the panel and tried pushing the window up from the bottom while pushing the button up. No luck. Looks like the last couple teeth on the regulator might be whats keeping it from rolling up and the motor gets hot after trying for a few minutes. Fuses are good and all that. Anyone have any advice on how to get it back up???
Re: eg passenger power window help!!
Sounds like a mechanical problem of the regulator being damaged. Which needs to be replaced. In the mean time u can somehow loosen the two window bolts. Then just slide the window up & use duct tape or a piece of wood to keep it up. Until you have a replacement regulator & i'd recommend a run channel as well.
Until you replace the part(s) you can unscrew the motor from the regulator and reposition the sector gear on the motor then put the motor back on so you can roll the window up. That way it is secure and you aren't the guy with a taped up window rolling down the road.
