eg interior door handle lock problem
Old 11-22-2004, 12:54 PM
jlsmi2's Avatar
Default eg interior door handle lock problem
For starters I have a 1992 Civic Cx. On the interior door handle, the LOCK switch is broken. When I removed the door panel it was apparent that the metal lock rod (that runs to the outside door handle) separated from the plastic "lock" mechanism attached to the interior door handle.
I went to a local Honda Dealer and they informed me that I could not just buy the plastic lock handle (says 'lock' on it in case you don't know what i'm talking about).
They showed me the diagram and it does indicate that Honda does not sell this piece seperately. Does anyone know if its possible to take this piece out of a junk yard Civic and clipping it back in place? Would this be difficult to do w/o breaking it? Anyone know if this part MAY be available from honda or aftermarket seperate from the rest of the door handle?
Any help would be appreciated. The handle retails for $70 and I'd rather avoid buying the whole thing.
Thanks for info/suggestions
Old 11-22-2004, 12:58 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: eg interior door handle lock problem (jlsmi2)
Junkyard dude. Those things break all the time. If your locks freeze in the winter and you try to lock them from the inside, they break off. Just try your local junkyard.
Old 11-22-2004, 01:35 PM
jlsmi2's Avatar
Default Re: eg interior door handle lock problem (JDM_Ej)
get whole handle @ junk yard or possible to just take the plastic piece? how difficult is it to take the metal rod off the plastic piece w/o damaging it in the process?
Old 11-22-2004, 01:51 PM
CL9WestCoastin's Avatar
if you're afriad of damaging it in the process then why not clip off about a couple of inches the metal rod and take it home and work with it when it is off the door. It would be much easier that way.
Old 11-22-2004, 02:07 PM
jboy08's Avatar
Default Re: eg interior door handle lock problem (loketran)
had the same problem, just ended up buying the whole assembly. not too hard of an install.
Old 11-22-2004, 02:19 PM
cxSHOE's Avatar
what side do you need? and you need to grease the area where it connects to the plastic or it comes loose after years.
Old 11-22-2004, 05:00 PM
98EJ's Avatar
Default Re: eg interior door handle lock problem (cxSHOE)
****, mine did the same thing on my 92. I was hoping you could just buy the little lock piece.
Old 11-22-2004, 07:48 PM
jlsmi2's Avatar
Default Re: eg interior door handle lock problem (98EJ)
I need passenger side. YEAP, looks like you can't just buy the plastic piece from Honda, that would make too much sense.
This is probably unlikely, but anyone have one of these lying around? Or an extra interior door handle?
Old 11-22-2004, 08:09 PM
cxSHOE's Avatar
cool thats the side i have...in grey let me know if you want it $15 bucks shipped.. let me know.ill put a photo of it in a few
Old 11-22-2004, 08:12 PM
dantastic's Avatar
mine broke too.... and the stealership is right. the **** part is not available separately. ebay and junkyards are your best bets for replacements
Old 11-22-2004, 08:36 PM
Calvinator's Avatar
Damn that happened to me too while trying to install my doorlock actuators.. I'm still looking for that plastic tab. It gets really annoying when you have to open your door with the key from the outside.hahaa
Old 11-22-2004, 08:44 PM
gunnis's Avatar
Default Re: eg interior door handle lock problem (xtremeazian)
My drivers door has his problem. Fortunatly my alarm has one power door lock on that same side(93coupe). I wouldn't mind fixing it though.
Old 11-22-2004, 10:33 PM
pinoyrukus's Avatar
dam!!! $70 , i would never pay so much, u could find those things on ebay for round 10 bux
Old 11-22-2004, 10:54 PM
Sliced Beard's Avatar
Default Re: eg interior door handle lock problem (pinoyrukus)
http://www.hondaautomotiveparts.com
Old 11-22-2004, 11:53 PM
taney's Avatar
i've got door handles sticking around ..
aim me: taney.dich@mac.com
Old 11-24-2004, 12:27 PM
jlsmi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">Damn that happened to me too while trying to install my doorlock actuators.. I'm still looking for that plastic tab. It gets really annoying when you have to open your door with the key from the outside.hahaa</TD></TR></TABLE>
I feel your pain. For a while I had the panels off and just used the metal rod. Didn't go over so well with passengers....haha
Old 11-24-2004, 03:03 PM
cxSHOE's Avatar
pm replied Jacob
Old 11-24-2004, 05:18 PM
Terrabomb's Avatar
yep you only need that little peice. Just remove the pin thing that goes through it and replace it. Stick the pin back in and wala, your set.
Andrew
Old 11-24-2004, 05:26 PM
Boba Connoisseur
SkyeC's Avatar
Default Re: eg interior door handle lock problem (Terrabomb)
If anyone has a pair of black driver and passenger side handles, let me know.
Both of mine have broken over the past 5 years and it's getting slightly annoying. At least nobody can unlock my car without a key.
Old 11-24-2004, 05:39 PM
stripes777's Avatar
my driver side came broken, and about 2 weeks after buying the car, my frined broke the passenger side. he held the door handle open while i pressed the auto door locks and it jus snapped.
however, take this into consideration. im glad they are broken since i got auto door locks anyways. with it broke, peopel cant do the ghetto hanger trick through ya window to unlock your cars!!
Old 11-24-2004, 11:48 PM
jlsmi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Terrabomb &raquo;</TD></TR><TR><TD CLASS="quote">yep you only need that little peice. Just remove the pin thing that goes through it and replace it. Stick the pin back in and wala, your set.
Andrew </TD></TR></TABLE>
Unfortunately, you cannot buy that little piece from Honda....
MikhailM
07-23-2017 05:21 PM
LilTheo
11-04-2010 12:30 PM
bluenc-87
03-17-2010 04:55 PM
92 EH2
09-11-2009 08:52 AM
benSC
16
06-10-2004 07:43 PM
Quick Reply: eg interior door handle lock problem
