EG Electrical problem, headlights work but nothing else does - Honda-Tech
Old 12-21-2011, 05:21 PM   #1
Icon2 EG Electrical problem, headlights work but nothing else does
Hi everyone...
Ive got a problem with my buddies EG coupe. long story short a friend of his "helped" him out by moving his car so it dident get towed and put it on a trailer and moved it for him. When they did it the wheel was locked so they ripped out the ignition to unlock the steering wheel. i just replaced the whole ignition assembly for him and we still have nothing. The headlights come on but it dosent do anything else, and i mean nothing. no turn signals no starter no windows its just dead. This is my first ignition ive done and im honestly stumped.
any help is greatly appreciated
Thanks in advance
Eddie
Navy_CRX is offline   Reply With Quote
Old 12-22-2011, 03:14 AM   #2
Default Re: EG Electrical problem, headlights work but nothing else does
Bump
Old 12-22-2011, 04:44 AM   #3
The Grumpiest
grumblemarc's Avatar
Was the car even running prior to relocation and the butchery done to it? Better locate some wiring diagrams and start checking your work. No way to tell what damage was done nor how you did the repair.
grumblemarc is offline   Reply With Quote
Old 12-22-2011, 03:44 PM   #4
Car wasent running before i did the ignition but it at least cranked and the windows worked and what not. When i replaced the ignition i kinda feel like it was idiot proof due to it only having 2 plugs on it and they arent interchangable. We got it to crank with the bad ignition if we used a screwdriver to ground the tumbler and turned it with another screwdriver. At first i was thinking it might be a bad ground but i used my battery charger and jumped the small wire on the starter and it cranks fine.
Sorry about the ramble but im really stumped on it
Thanks in advance
Eddie
Old 12-23-2011, 10:35 AM   #5
bump
Old 12-23-2011, 02:19 PM   #6
delsolo95's Avatar
manual or auto? the manual differs from the auto just saying..pics of install avail. sounds like something on the harness isnt correct if only the head lights work which means that the car isnt even in I or II postion.
delsolo95 is offline   Reply With Quote
Old 12-23-2011, 02:27 PM   #7
Its a manual and i compared the two ignition plug wires and they are the same and hooked up in the correct spots
Old 12-23-2011, 06:30 PM   #8
delsolo95's Avatar
i didnt see this. the key tumbler has to be replaced then.. im not sure what your asking now. either the power doesnt turn on with the key turned or you cant get it to start bc you said it just cranks
Help please eg8 dohc zc - electrical problems Jordan_abbott90 Honda Civic / Del Sol (1992 - 2000) 34 06-30-2013 10:08 AM
HELP. Changed Ignition no Start SMOOTHN Acura Integra 6 02-12-2010 08:33 AM
Car will not start - No interior electrical - Headlights & Horn do Lone_Bassist Honda Accord (1990 - 2002) 26 05-09-2009 06:54 AM
Where is L-CON? 8point6 Welding / Fabrication 15 10-17-2005 08:24 PM
Matt Short AKA- H22poweredslow AKA- jdmh22lude is a scammer please help ensracer For Sale 8 08-23-2004 10:12 AM
Tags
1990, acura, civic, crx, electric, electrical, electricity, head, headlights, honda, ligghts, problem, tech, turn, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
