EG driver side window not rolling up correctly
Old 04-14-2011, 05:29 PM
odie88's Avatar
Default EG driver side window not rolling up correctly
First of all i want to say i tried searching for another post like that but couldn't find one so sorry if there is a post about this somewhere.I bought a 95 civic hb a little bit ago and the guy said the driver side window was not working he replaced the regulator but for some reason it still didn't work and the other day i took the door apart to look and the tab on the window was broken.So i went and purchased a new window.I put the window in today and when you go to roll it up the back of the window pushes towards the front of the door and comes out of the track and the front seems like it drops down.does anyone know how to fix this or anything to do to solve this issue?
Old 04-14-2011, 07:10 PM
BlackCivicEX's Avatar
Default Re: EG driver side window not rolling up correctly
Use liquid silicone stuff for the tracks. Lube them up, might be sticky
Old 04-14-2011, 09:22 PM
Wdpfreak145's Avatar
You can adjust this by moving the torque screw for the motor assembly up or down. there is one screw that goes into a vertical slot. Moving this up or down will change how the motor torques. I did this to mine and it works- to an extent. There is still a small gap in the back of my door when I roll the window all the way up. But if i get out and push it back by grabbing the window with both hands, it lines back up for that one time. Perhaps the rubber trims need greased? Something so it doesnt grab onto the window so tightly and cause it to drag back up.
Old 04-16-2011, 09:22 AM
odie88's Avatar
thanks for the replies guys i ended up going to the local junk yard and pulled a regulator and replaced mine.The guy who owned the car used some cheap replacement i think cuz it wasnt bent was just a POS.Lubbed the tracks and everything works now just really stiff when it rolls up
mattyfo0z
01-07-2011 09:46 PM
turbotuner
05-31-2010 09:27 PM
wdissident
01-20-2009 01:29 PM
deerman2701
11-27-2007 05:59 AM
EnKidu
10-10-2004 06:43 PM
Quick Reply: EG driver side window not rolling up correctly
