Eg Dash Wiring
Eg Dash Wiring
car was stolen and I now have every peice to put it back together except for the wiring for the dash. I know this is marketplace stuff but I am actually not sure what I need. I believe it is the wiring harness from the fusebox to the dash according to my friend. it was taken when they stole my si cluster. if anyone can confirm this and shed some light so i don't start a manhunt for a part without knowing anything about it that'd be awesome
Re: Eg Dash Wiring
The question I pose to you is, what wiring do you have right now? Can you take pictures of what you have without the dash in the car? Or, can you photograph the wiring that you have?
Re: Eg Dash Wiring
I can't because it is actually at the shop right now... in fact i haven't seen the car in a while but i am told that it is the fusebox to the cluster that I need. I am wondering though if this wire is it's own seperate component or if it is a bundle of wires.... the thieves took the whole wire when they stole my cluster and managed to cut my entire dashboard with a razor... i finally found a replacement si dashboard since unfortunately it is different than the other models and when i went to pick up the car my guy said he couldnt put it in yet because the fusebox to cluster wire on the dash he ordered was cut... so now I take on the job of finding out exactly what that peice looks like and if anyone has one cause he can't seem to find one at local junkyards
Re: Eg Dash Wiring
i am assuming i can't buy that wire seperate from the others? or maybe i can? but if i do need the entire dash harness i guess my question becomes whether or not all of the eg dash harnesses are the same or if i need to have an si or ex one
d16vteceg
04-27-2006 11:04 AM
