ECU Code Check Question
Old 01-14-2005, 11:56 PM
jaycapz's Avatar
Default ECU Code Check Question
I searched the forums and couldnt find the answer.
I have a 2000 honda civic, and i did the jumper on the service plug....
When I turn it to ON, the check engine light stays on, and the SRS light flashes once, then comes back on. Is this normal?
Without the jumper, the car in on the check engine light and SRS light go out after 3 seconds.
Thanks!
Old 01-15-2005, 12:23 AM
resol's Avatar
Default Re: ECU Code Check Question (jaycapz)
its suppose to go off after 3 seconds without the jumper..what was the reason for puttin the jumper in anyways if u didn't have a cel?
Old 01-15-2005, 08:37 AM
jaycapz's Avatar
Default Re: ECU Code Check Question (resol)
I am getting a jumpy engine syndrome, wanted to see if i could check for codes using the jumper method on the service plug. See if theres something on the basics i can do without killing myself at first.
So, i tried it... and all i got was a steady engine light and 1 pulse from the SRS light.
Old 01-15-2005, 02:45 PM
resol's Avatar
i mean if the cel isn't comin on then i wouldn't worrie about it... but if it is.. then pull over to the side and KEEP THE CAR ON.. then plug up the jumper.
Old 01-15-2005, 02:49 PM
cherroneballs's Avatar
yeahmy 98 will stay on if I have a jumper hooked up even though there is no cel it's normal.
Old 01-22-2005, 02:16 PM
Zekers's Avatar
I thought that in order to pull the codes from the On Board Diagnostics you have to have your car off when you insert the jumper and THEN turn your car on. And after that you can interpret the codes from the flashes that your CEL does.
Old 01-22-2005, 02:29 PM
ian.'s Avatar
Default Re: ECU Code Check Question (Zekers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zekers &raquo;</TD></TR><TR><TD CLASS="quote">On Board Diagnostics</TD></TR></TABLE>
we like to call that a ecu and the car doesn't have to be all the way on you just put the key in the on position
Rupinder Summan
07-10-2014 02:47 PM
8_UR_AWD
Honda Civic (2001 - 2005)
13
03-08-2009 06:19 PM
nguyennhatquang
11-16-2005 02:32 AM
DjFreeze
18
04-29-2004 04:31 AM
sackdz
06-23-2001 09:36 AM
Quick Reply: ECU Code Check Question
