ECM/PCM Location? - Honda-Tech
ECM/PCM Location?
Old 01-07-2010, 06:05 PM   #1
New User
Icon6 ECM/PCM Location?
I am trying to troubleshoot a no-start 1997 Civic CX (D16Y7). I'm thinking it might be an ignition issue so I'm going through the ICM input test per the factory service manual. It states:
"Disconnect the ECM/PCM connector A (32P)."
Where is this thing?
Any other troubleshooting clues would also be appreciated. So far I've tested the basic four components (fuel, spark, compression and timing). They all seem to exist but are probably not in the amounts needed to start the pup.
Thanks!
mr. boffo is offline   Reply With Quote
Old 01-07-2010, 06:23 PM   #2
-Gambit-'s Avatar
Default Re: ECM/PCM Location?
passenger side kick panel under the glove box
-Gambit- is offline   Reply With Quote
Old 01-07-2010, 06:33 PM   #3
89hatchallmotor's Avatar
Quote:
yes sir thats where it is just like any 92-00
89hatchallmotor is offline   Reply With Quote
Old 01-08-2010, 01:25 PM   #4
New User
Got it, thanks!
Old 01-08-2010, 04:04 PM   #5
canadaek's Avatar
do you have a tach ? if you do and it doesn't move when cranking your igniter is more than likely bad. Have you checked for code's ??
canadaek is offline   Reply With Quote
Old 01-11-2010, 11:51 AM   #6
New User
I did replace the ICM but there was no change. The spark is definitely yellow/orange, is that a definitive symptom?
2000 Distributor questions HondaMizzan Honda Accord (1990 - 2002) 7 08-01-2015 04:13 PM
Diagnosing and replacing ECM/PCM in '00 CRV mypsi Honda Element & CR-V 3 03-23-2015 05:42 PM
2011 Sedan Mods (PCM, Immobi) x2aws Honda Accord & Crosstour (2003 - Current) 1 10-23-2013 03:25 PM
HELP!!! ELD, CKS, ECM/PCM, Coil - No Spark docppo Honda Element & CR-V 4 06-21-2011 05:54 AM
ecm/pcm relay fuse eddygp Honda Element & CR-V 0 10-02-2010 08:57 PM
Tags
1997, 2005, 97, accord, box, civic, connector, ecm, ecmpcm, honda, location, odyssey, pcm, prelude, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
