which ecm is compatible? - Honda-Tech
Old 11-26-2007, 09:39 AM   #1
5thGenFanatic's Avatar
Default which ecm is compatible?
i have to replace the ecm in my 92 civic dx... but i have a b18b1 swap with a manual trans... my ecm part number is 37820-pr4-L11.. it says 92 integra 5speed on the ecm.. but i know the motor in my car is from a 94+ integra, and the map sensor is from a 91 integra...so im pretty sure most of the parts are interchangable from a 91 teg to 97 at least because ive never had a problem with my car in over 2 years, but i would like to know if anyone has a list of definite acceptable ecm's that i could use in a civic/b18b1 manual trans or if theres only a certain one i should be using?
5thGenFanatic is offline   Reply With Quote
Old 11-26-2007, 10:30 AM   #2
usdmed9's Avatar
Default Re: which ecm is compatible? (5thGenFanatic)
any obd-1 manual ls ecu will work
usdmed9 is offline   Reply With Quote
Old 11-26-2007, 12:23 PM   #3
groundzerocivic's Avatar
Quote:
i have a 93 pr4 ls ecu.......that i dont need
groundzerocivic is offline   Reply With Quote
Old 11-26-2007, 12:27 PM   #4
fmrprojects's Avatar
Default Re: which ecm is compatible? (groundzerocivic)
get a 94-95 ecu. the 92-93 has a extra oil pressure switch on the back of the block so it looks for it.
fmrprojects is offline   Reply With Quote
Old 11-26-2007, 12:29 PM   #5
Default Re: which ecm is compatible? (fmrprojects)
Quote:
really????? didnt know that cuz im runnin a p28 with hondata....thanx fer the heads up....
Old 11-26-2007, 01:06 PM   #6
thanks for all the replies
2003 civic ex ecm Zlehman83 Honda Civic (2001 - 2005) 0 04-06-2016 05:03 PM
How-To Wire Automatic B18B1 into EG Chassis (Pic Heavy!) crzdmngz Hybrid / Engine Swaps 15 08-20-2014 06:07 AM
95 Civic DX - no spark or fuel. Is it the ECM? horseyj18 Honda Civic / Del Sol (1992 - 2000) 12 04-20-2014 06:52 AM
***NEED HELP*** AP2 CLUSTER MODIFRY ECT B20PWRD Honda Civic / Del Sol (1992 - 2000) 3 04-27-2011 08:20 AM
1996 Del Sol ECM joewhiteside Honda Civic / Del Sol (1992 - 2000) 7 03-06-2008 06:10 PM
Tags
1992, 2000, 37820pr4l11, 92, accord, b18b1, civic, crx, ecm, honda, map, pr4, replacement, sale, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
