Where am i leaking from ???
Old 03-22-2010, 10:47 AM
T Thrash 09's Avatar
Default Where am i leaking from ???
ok so i have a 95 civic d16z6 and it leaves a good sized puddle every time i park for like an hour or so. I have replaced the oil pan gasket and the rear main seal . Now for some info there is oil on my tranny dripping on my exhaust and on my oil pan so what do you guys think ?
Old 03-22-2010, 10:59 AM
Ruben19's Avatar
Default Re: Where am i leaking from ???
pictures?
get it fix asap
Old 03-22-2010, 11:07 AM
Linked's Avatar
check the top of the engine, sohc's notoriously leak oil from the distributor o-ring
JKov240's Avatar
Perhaps the large o-ring behind the oil filter? (Not on the filter itself, the housing the filter screws to has an o-ring)
Clean it all off, drive it for a bit and see if you can locate the source.
Old 03-22-2010, 11:58 AM
96hb's Avatar
Check your distributor o-ring and your valve cover gasket.
Old 03-22-2010, 12:41 PM
delsolo95's Avatar
Ever checked the trasmission seals?? v-tec solenoid, dizzy O ring... most common
Old 03-22-2010, 12:46 PM
kaiba's Avatar
Drain plug crusher washer?
Old 03-22-2010, 01:51 PM
4g4dcruisin's Avatar
He said drips onto the oil pan...
have you checked your head gasket?
Old 03-23-2010, 09:14 AM
i believe i found out what it is i put my hand under the vtec solinoid and it was dripping oil so im guessing its the gasket
Old 03-23-2010, 09:36 AM
Dealer only item, autozone, kragen, pepboys, napa had no clue what i meant by, "vtec solenoid gasket".
Old 03-24-2010, 05:25 AM
yup called all theses places and they were like theres nop such thing are you sure thats the name. how much did you pay for it at the dealer?
Old 03-24-2010, 05:26 AM
yup called all theses places and they were like theres nope such thing are you sure thats the name. how much did you pay for it at the dealer?
Old 03-24-2010, 06:39 AM
Around $15 or so. Its the dealer, they always rape you.
Old 03-25-2010, 05:31 AM
dvd5904's Avatar
I had the same issue with mine. You might as well replace the oil pressure switch gasket (another dealer item) while you're working on the VTEC solenoid. It is mounted on top of the solenoid.
JDMob
01-26-2020 11:17 AM
blacktibby07
21
02-03-2011 04:42 AM
davey5300
05-07-2010 06:01 PM
granny racer
09-22-2009 01:17 PM
MeanGreenEG9
01-13-2003 11:09 AM
Quick Reply: Where am i leaking from ???
