easiest way to replace cam seal (B18c1 motor)
Old 10-24-2007, 02:05 PM
jdmjeff's Avatar
Default easiest way to replace cam seal (B18c1 motor)
i need to replace my cam seal in my gsr motor. can i just take the v/c off and unscrew the 2 10mm bolts that hold on the end of the exhaust cam and replace it that way or do i HAVE to take the cam out and take the timing belt off? thanks
Old 10-24-2007, 04:15 PM
jdmjeff's Avatar
Default Re: easiest way to replace cam seal (jdmjeff)
up!
Old 10-24-2007, 04:45 PM
VRD^sam's Avatar
you dont have to take out the cam or timing belt. just the cam seal cap
Old 10-24-2007, 04:47 PM
dc2doi's Avatar
Default Re: easiest way to replace cam seal (VRD^sam)
Remove the 2 14mm bolts on the cam gear to get to the cam seal.
No need of removing the whole camshalf.
You would have to do the timing belt again.
Old 10-24-2007, 04:50 PM
1992Si's Avatar
Just did this last week. B18B1, Dizzy end
Remove Valve cover.
remove 4 bolts that hold the seal and that end of the cam.
Tap the cap lightly with a hammer and punch or what ever to loosen it.
Pick it up and remove the old seal.
Install new seal...I think you can figure out the rest.
Here's a picture http://www.acuraautomotivepart...ormal
Oh I see the GSR does only have two bolts.
Old 10-24-2007, 05:18 PM
jdmjeff's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Just did this last week. B18B1, Dizzy end
Remove Valve cover.
Oh I see the GSR does only have two bolts.</TD></TR></TABLE>
sweet thanks man
Old 12-17-2007, 02:19 AM
brainglow's Avatar
Default Re: (jdmjeff)
im about to do the cam seal replacement as well (dont mean the thread jack) on my gfs 96 ls auto integ. i just want to know how many lbs of torque do i set the head bolts to?
hondacivkev
07-09-2011 11:09 AM
EdGe(161)
04-11-2011 09:28 AM
MR Rodgers
06-26-2007 09:46 PM
4DRmafia
12-22-2005 08:45 PM
B18CR-X
10-03-2005 07:50 PM
Quick Reply: easiest way to replace cam seal (B18c1 motor)
