Duralast vs. Brembo
Old 07-26-2007, 09:27 AM
meangreenEG's Avatar
Default Duralast vs. Brembo
I need new rotors, so I might as well ask all of you what you think is better... Duralast or Brembo rotors.... and should I get drilled and slotted or just blanks.. by the way I have discs in the front and drums in the back, no ABS.
Old 07-26-2007, 09:30 AM
95ProjectEJ1's Avatar
Default Re: Duralast vs. Brembo (meangreenEG)
Duralast FTW!!! Cheap and effective.
Old 07-26-2007, 09:38 AM
Darth ModerVader
Padawan's Avatar
Default Re: Duralast vs. Brembo (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Duralast</TD></TR></TABLE>
AutoZone/Duralast blanks are fine.
Old 07-26-2007, 09:40 AM
Ek Forever y0!
Libertariat's Avatar
Default Re: Duralast vs. Brembo (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
AutoZone/Duralast blanks are fine. </TD></TR></TABLE>
Even if there is a difference, I'm positive it's minimal. Better pads/fluid would make more of a difference than the difference in those rotors.
Old 07-26-2007, 09:45 AM
Probot's Avatar
Default Re: Duralast vs. Brembo (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Even if there is a difference, I'm positive it's minimal. Better pads/fluid would make more of a difference than the difference in those rotors.</TD></TR></TABLE>
yea what he said
get like ebc green stuff pads or hawk pads
you stop realll good
Old 07-26-2007, 01:16 PM
Default Re: Duralast vs. Brembo (Probot)
So to remove my stock rotors i need to hammer out the screw? I don't wanna strip it.... and how do I put it back on?
Old 07-26-2007, 01:20 PM
Ek Forever y0!
If it won't screw out with mild effort, hit it with some pb blaster. If that doesn't work, get an impact screwdriver.
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">So to remove my stock rotors i need to hammer out the screw? I don't wanna strip it.... and how do I put it back on? </TD></TR></TABLE>
it's not just hammering it out. you will need a impact driver. this what it looks like:
http://www.brownells.com/aspx/...=7932
if they do happen to get stripped, because they can and possible will. the easiest way to remove them is to drill them out. unfortunatly i don't have my drill bit set to tell you what size, but it has to be narrow enough to go through the hole on the spindle/hub.
it's quite simple, not as bad as it sounds.
Ek Forever y0!
Default Re: Duralast vs. Brembo (philosofy1)
Synchronized posting FTW
Old 07-26-2007, 01:33 PM
gtlaw1's Avatar
depending on cost get the brembos... I have them on my 91 se-r with metal master pads which I expected to eat up the rotors. two years later the rotors look nearly new.. I doubt that generic rotors would have held up as well. BTW I got the brembos from nopi for a very reasonable price
Old 07-26-2007, 01:37 PM
bara6075's Avatar
The good thing about Duralast is lifetime warranty
gtlaw1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
it's quite simple, not as bad as it sounds.</TD></TR></TABLE>
if you do end up drilling it out there is no need to go as far as the hub all you have to do is get the chamfered head to fall off then the rotor will come off. the bolt is m8 so a 5/16 drill bit should work
Old 07-26-2007, 01:42 PM
philosofy1's Avatar
Default Re: Duralast vs. Brembo (gtlaw1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtlaw1 &raquo;</TD></TR><TR><TD CLASS="quote">
if you do end up drilling it out there is no need to go as far as the hub all you have to do is get the chamfered head to fall off then the rotor will come off. the bolt is m8 so a 5/16 drill bit should work</TD></TR></TABLE>
i don't even deal with the impact driver, too time consuming.
Old 07-26-2007, 01:44 PM
97civicdx's Avatar
Duralast is fine. If you want to spend the extra $$$ on Brembo's then all the more power to you. Its your money...........
Old 07-26-2007, 01:52 PM
Ek Forever y0!
Default Re: Duralast vs. Brembo (97civicdx)
Brembo rotors go for about $29 Each.
Duralast Are $27 Each
In this case, I'd say get the brembo's for the $4 difference.
Who knows, it might have a slightly different/better composition.
Old 07-26-2007, 01:53 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Brembo rotors go for about $29 Each.
Who knows, it might have a slightly different/better composition.</TD></TR></TABLE>
brembo for $29? where? GIVE THAT LINK!
Old 07-26-2007, 01:55 PM
Ek Forever y0!
https://honda-tech.com/zerothread?id=831188
Old 07-26-2007, 02:04 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=831188
Old 07-26-2007, 02:52 PM
ejprimo's Avatar
i just use valuecraft rotors from autozone for $17 each.
Old 07-26-2007, 03:05 PM
Relic1's Avatar
great place if you're closer to WA than chicago.
you can save a few bucks if you go with 88rotors.
IRP - 29x2 + 22*2 + 18-25(s&h) = 120-127
88 - 65 + 52 = 117
https://honda-tech.com/zerothread?id=1411597
OP: The brembos tend to wear longer if you're going to push the car really hard (ie multiple lap track sessions).
For a street machine that may get pushed from time to time it can go either way, which ever you can get cheaper.
Old 07-26-2007, 03:33 PM
gtlaw1's Avatar
yeah its all about the metallurgy. can't comment on the duralast, but I seen cheap rotors that only last as long as the equally cheap pads thet were used with
Old 07-27-2007, 07:18 AM
Thanks for all the help
Old 07-28-2007, 12:31 AM
JDMbiAtcH's Avatar
get the brembos...................
chairwitharmrests
09-03-2007 03:40 PM
infinkc
12
03-09-2007 10:10 AM
blacksniper
11
07-26-2004 03:03 PM
tekstyle
10-30-2003 07:26 PM
Doeboy
10
09-18-2003 09:57 AM
Quick Reply: Duralast vs. Brembo
