Drum Brakes making noise...
First off its a 97 CRV but I'm sure you guys can help.
About 10,000 km ago my drums were making a shuffling/clunking sound whenever i braked. It made a sound at every revolution of the wheel ,first fast then slow as I came to a stop. I then took the drum covers off then cleaned them and the problem dissapeared.
The problem is back now and I cleaned the dust off of them but that did not help like the last time that this noise happened. Drum shoes look fine, is there a minimum thickness of the shoes at which they should be replaced? My car only has 170,000 km (not miles).
I'm thinking the drums should be turned. Any other thoughts?
Re: Drum Brakes making noise... (miksew)
With ~105mi on the car, I'd say they probably need to be replaced.
IIRC, minimum is about 4/32" when measured from the rivets.
Re: Drum Brakes making noise... (t0p_sh0tta)
We are close to that on miles and our rear shoes where shot. I also put some water proof grease on the spot where the shoes slide on. Now there is no noise.
chrisjm00
11-12-2005 09:37 AM
redpeppers
09-03-2005 08:21 PM
redpeppers
16
08-25-2005 07:46 PM
