Driveshaft clearance in gearbox!? - Honda-Tech
Old 07-06-2006, 12:24 PM   #1
ApOE's Avatar
Default Driveshaft clearance in gearbox!?
Iíve been visiting Honda-tech for some time, and Iíve read allot of great info!
First of all, sorry if I donít write this in perfect English.
I swapt a B16A2 into my 94í EJ Coupť this weekend, all went well except for some problems with a driveshaft. The Right (When I you sit in the car) driveshaft didnít want to go out of the gearbox, and I didnít have a crowbar so I disassembled this part: (Donít know how you call it in Enlgish)
leaving this part in the gearbox:
When I tried to take that part out of the gearbox I noticed that it had some clearance, I can move it up and down a few millimetres and while doing that I can hear a slight rattle. I thought that it was ok and assembled the axle.
Now that Iím driving my new engine for a few I day I start hearing a strange noise coming from the front right side of my car, itís a cracking/rattling sound that only lasts for a few seconds. It doesnít always make the sound but it mostly happens when turning my steering wheel completely to the right(While driving), when braking hard and taking speed bumps. The first thing that I thought of was the drive shaft, but I canít find anything wrong whit it except for the clearance that I found.
My question is: is the clearance normal? Can it hurt my gearbox or is it already broken?
Thanx!
ApOE is offline   Reply With Quote
Old 07-06-2006, 12:29 PM   #2
philosofy1's Avatar
Default Re: Driveshaft clearance in gearbox!? (ApOE)
why wouldn't you just get or borrow a prybar? you just made your job harder.
you need to replace your axle. the joints on the inside are bad, that is why you hear the clicking noise when you turn.
as far as clearance, if the axle is not completely in the tranny you would be leaking tranny fluid.
philosofy1 is offline   Reply With Quote
Old 07-06-2006, 12:30 PM   #3
EK79's Avatar
have no clue why you disassembled this part.......you have to grab the axle and pull hard as **** to release it there is a small ring that hold the axel in
EK79 is offline   Reply With Quote
Old 07-06-2006, 12:44 PM   #4
ApOE's Avatar
Yeah I know how to remove the axle, but we couldn't get the shaft out. I had to replace the rubber thing (What do you call it) at the end of the shaft. That's why we didn't want to spend hours on it and just disassembled it. So if anything is wrong whit the gearbox it would have leaked tranny fluid? That's a relief.
Modified by ApOE at 10:00 PM 7/6/2006
Old 07-06-2006, 12:54 PM   #5
Unceasing Measure
Archidictus's Avatar
Default Re: (ApOE)
Quote:
The rubber thing is called a "boot" and I think your problem is that you ruptured the CV joint when you took it apart and now it won't remesh properly. You'll have to get a new CV axle from a local parts store to make the issue go away. Good luck.
Archidictus is offline   Reply With Quote
Old 07-06-2006, 12:58 PM   #6
philosofy1's Avatar
Default Re: (ApOE)
i had said if the axle is not all the way in then it will leak. if there was something wrong with your gear box then that's something else. in the situation of the gear box it'll only leak if the housing or seals are broken. in your case i doubt your box is bad. just replace your axle the right way and the problem should be gone.
Old 07-06-2006, 01:04 PM   #7
ApOE's Avatar
Thanx for your quick reply's!
Old 07-08-2006, 08:42 AM   #8
ApOE's Avatar
I changed the drive shaft today, but with no luck. The noise is still there
The sound is getting worse now, when I turn my steering wheel while standing still its there, and every time I hit the brakes it there?! Could this be a bad ball joint?
Old 07-08-2006, 08:44 AM   #9
ApOE's Avatar
Btw, I bought a Crowbar
Old 07-08-2006, 08:58 AM   #10
littleblue's Avatar
Location: On a island w/ only a bridge to leave it, U.S.A
Default Re: (ApOE)
rofl
littleblue is offline   Reply With Quote
Old 07-08-2006, 11:04 AM   #11
philosofy1's Avatar
Default Re: (ApOE)
wow, check the all the ball joint, upper, lower and tie rod. look for lose bolts, maybe when putting everything back together you forgot to tighten a bolt.
Old 07-08-2006, 11:25 AM   #12
CRXified's Avatar
or it could be the axel on the other side starting to take a crap
CRXified is offline   Reply With Quote
Old 07-11-2006, 01:22 PM   #13
ApOE's Avatar
Problem solved, it was the lower balljoint.!
DIY J30A4 Swap into EG Civic race car Redlina Road Racing / Autocross & Time Attack 22 03-15-2015 01:37 PM
Time for another Engine - Please help me decide! rodhay Honda Prelude 14 05-27-2010 10:25 AM
honda civic vti gearbox tranny problems navtec Tech / Misc 0 12-22-2007 05:11 PM
Driveshaft problems?? skeg8 Honda Civic / Del Sol (1992 - 2000) 3 03-06-2006 11:11 AM
Question about ITR Gearbox... REDTOPAlchemy Acura Integra Type-R 12 07-21-2004 02:41 PM
Tags
axle, clearance, gearbox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
