Door jamb switch..
1 Post
Door jamb switch..
Would a faulty "djs" as i've called it, make the dome light flicker and eventually go out..?? Like if one was "going" bad, would it make the light actually flicker on an off, without any door actions being taken -open/closed-...??
And someone once said they replaced their "djs" at autozone or something relevant, is this honestly true..??
1 Post
Re: Door jamb switch.. (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">Yes thats true.</TD></TR></TABLE>
Thanks friend...
Thanks friend...
I would be testing the "djs" before jumping to conclusions about it being the cause of the flickering light.
Yes, it could be the cause...but the dome itself could have bad ground or bad 12v contact.
The door jam switch just provides a ground, when the door is open...pretty hard for it to go bad.
(Im guessing you have that rating because youre too much of an *** in other threads...theres a limit)
HRD PKR
Re: (pdiggitydogg)
Could be your door out of adjustment also, Here at work we have alot of "djs" go bad... But i agree with him^ I would test it with a known good one from a friends car or test the actuall switch..
1 Post
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I would be testing the "djs" before jumping to conclusions about it being the cause of the flickering light.
(Im guessing you have that rating because youre too much of an *** in other threads...theres a limit)</TD></TR></TABLE>
true, well yeah i tried to ground out the switch to test it today an had no luck... an the fuse is good... hmmm, above the bulb on the dome light it looks like that area burnt a lil, like burnt a hole through the top or something, maybe it did some kinda overheat maneouver on me...
an yeah ur guess is right, i am an *******.. but its alright cuz i really dont give a **** because i help out WAYYYYY more than I contribute to being an *******... Just something to aggrivating about people that act like their the ****, or kno more than u, or compare their cars over the internet, that really gets on last nerve... So instead of being a little bitch an keeping quiet about it, I go with my italian instinct and let them kno exactly how I feel about their lovely attitude...
1 Post
Re: (JDM_SOHC)
hmm, i just tried to turn on the lights with key in acc an it doesnt beep.. im not sure if it ever did but im thinkin this might have something to do with my **** not workin... i just did the search of all searches "ht, d-series, google, yahoo, ect" and in NONE of them does it ever mention exactly what could be the cause of this problem... kinda weird...
For a switch to go bad, that is working off 1 circuit given power by a fuse seems odd when the fuse is good an all the wiring seems fine...
1 Post
Re: (JDM_SOHC)
bump for an answer to help ALL of us 5th gen fellas with dome light issues...
so far - my dome light doesnt work at all, fuse is good, an the door jamb switch didnt wanna work when i messed with it as well... an also my car doesnt beep with key in igntion an lights on with door open, but like i said not sure if mine ever beeped or not..
Re: Door jamb switch.. (JDM_SOHC)
i know coupes 96-98 had a bulletin out on the dome light having problems. somthing about the contacts for the switch would loose flexibility. i can't remeber if the heat from the bulb melting the plastic had anything to do with it but i want to say it did.
mine flickers in the "on" position. it's annoying. pull the light out and look at the contacts. you may be able to see the problem there.
1 Post
Re: Door jamb switch.. (hondamark35)
yeah dude i took the dome light itself down an the melted plastic doesnt look like it affected anything else, everything still appears to be in newer condition.. the contacts all seem clean an everything.. just bought new bulb couple days ago so i kno thats not my issue.. an the funny thing is that mine was doin that flickerin **** before it died for good.. like couple days before hand it was flickerin on n off an **** while i was drivin, than i got home an checked an it was to late, that bitch cut took its last breath at 8:38pm on the night of December 9th, 2007
Myechtatel
07-14-2013 08:31 PM
jaysin04
11-22-2008 12:44 AM
