Does your 02 sensor effect your gas mileage?
Old 07-08-2009, 08:12 PM
wonTuansoup's Avatar
Default Does your 02 sensor effect your gas mileage?
My question is:
Does your 02 sensor effect gas mileage?
I have a 97 del sol. Installed ebay headers [only had one bung hole for one 02]
My car has 2 02 sensors. I took off the 02 sensor that was after the CAT.
Is this bad? i really don't mind the CEL but i'm wondering if this is effecting gas mileage.
Old 07-08-2009, 08:20 PM
iliv2xlr8's Avatar
Default Re: One questions
First thing... Please read the Forum Rules sticky. Create threads with proper subject matter, not just "help" or "one question"...
On to your issue. The second O2 is strictly for emissions purposes, it will not effect gas mileage.
I would suggest fixing the CEL. You could have other problems down the road and wouldn't know because your CEL would already be on, and it just looks goofy. To fix it you have a few options....
1. Search for an O2 simulator that plugs in where the 02 used to.
2. Weld in a bung
GL OP
Old 07-08-2009, 08:28 PM
okay, thanks. Btw, before i the header, i didn't have any issues with the car, no cel, the car ran perfect. The cel right now is because of 1:Header flow for the 1st 02 and 2:i don't have the 2nd 02 plugged in
Old 07-08-2009, 08:33 PM
iliv2xlr8's Avatar
Default Re: Does your 02 sensor effect your gas mileage?
Flow will not throw a CEL.....
The second 02 is strictly designed to measure hydrocarbons for emissions purposes. This in turn shows if your catalytic converter and other emissions equipment is functioning properly.
I assure you that if you scan your car it will be throwing a single code caused by the 2nd 02.
Did you eliminate the cat when installing the header? Test pipe?
Old 07-08-2009, 11:52 PM
yes
Old 07-09-2009, 01:12 AM
boostnbee's Avatar
just plug the secondary o2 back into the harness and ziptie it up to a)something on firewall b) something on the engine like intake mani c) anywhere it will reach
no need to weld a bung in or anything, secondary o2 is meant to be after cat where the air should be somewhat clean so dangling in the open will trick it to think its reading clean exhaust and Bam
NO CODES
Old 07-09-2009, 02:16 AM
MHDesigns's Avatar
NO CODES
Can anyone verify this? sounds logical to me.
Old 07-09-2009, 02:49 AM
2000siturboR's Avatar
yes i would like to know this too.
Old 07-09-2009, 07:52 AM
Former User's Avatar
NO CODES
I believe that dangling the secondary O2 sensor free should throw a CEL code because this sensor will detect high O2 levels (=very very lean condition). This will trigger a code by the ECU because high O2 levels are not expected at the secondary O2 sensor when the same condition does not exist at the primary O2 sensor.
Old 07-09-2009, 08:57 AM
boostnbee's Avatar
always worked for me, on a few eks so far. I hate obd2 cars and always find ways around stuff like that
Old 07-09-2009, 09:27 AM
rickkane's Avatar
How much power are you putting out?
Old 07-13-2009, 12:48 AM
I'm not sure if this have to do with my question. I'm running on a stock d16y7 with a header. [106hp via Honda]
Old 07-13-2009, 02:32 AM
Man U FTW
Schister66's Avatar
The first 02 sensor is the only one that really has any bearing on your gas mileage. It sees your AFRs in the exhaust pre-catalytic converter and adjusts fuel based on that. The second O2 merely keeps an eye on the catalytic converter. As long as it sees clean air and a certain amount of heat, it won't throw a CEL. Most people zip-tie this 02 sensor near the exhaust but let it dangle in free air. There are also 02 delete kits available online for very little $$ if you want to go that route.
Old 07-13-2009, 03:25 AM
2gnarly's Avatar
yes, youre o2 sensor effects your gas milage. I drive a 01 Acura Integra GSR and before i installed my new o2, i was getting about 170 miles to the tank. thats fu*king HORRIBLE! after i installed my new o2, im getting around 250-275 miles to the tank. it has improved 100 miles to the tank.
Old 07-13-2009, 05:37 AM
civic_ex2568's Avatar
can a faulty O2 sensor cause your car to lose power?
Championship
05-29-2007 12:31 AM
. M i c h a e l
01-18-2006 06:09 PM
Sijray21
07-08-2005 04:07 PM
WangChung
10-21-2003 02:47 PM
Quick Reply: Does your 02 sensor effect your gas mileage?
