Does it matter what order you put injectors in? - Honda-Tech
Old 03-04-2004, 08:21 PM   #1
Louie_EM1
Guest
Posts: n/a
Default Does it matter what order you put injectors in?
Im 99.9% sure it does not.
It's all wired up properly but it made me think when my buddie tells me cylinders numbers go (looking at the valve cover from left to right) 4,3,2,1
I always thought it was (looking at the valve cover from left to right) 1,2,3,4
Thanks.
Old 03-04-2004, 08:23 PM   #2
Ricey McRicerton's Avatar
Default Re: Does it matter what order you put injectors in? (Louie_EM1)
Ummm I don't really get what you are asking, but the wires will only reach the desired location.
Ricey McRicerton is offline   Reply With Quote
Old 03-04-2004, 08:42 PM   #3
lsvtec hatch05's Avatar
Default Re: Does it matter what order you put injectors in? (Ricey McRicerton)
i am wondering this question too. does it matter what order the injectors go in?
lsvtec hatch05 is offline   Reply With Quote
Old 03-04-2004, 08:45 PM   #4
Pooping on children
Discosteak's Avatar
my cats breath smells like cat food
what was your question again?
Discosteak is offline   Reply With Quote
Old 03-04-2004, 08:47 PM   #5
Default Re: Does it matter what order you put injectors in? (BADEG6)
does it matter what order the injectors go on the fuel rail, for the 3rd ******* time
Old 03-04-2004, 08:52 PM   #6
spnfed's Avatar
Left to right , 4/3/2/1.
spnfed is offline   Reply With Quote
Old 03-04-2004, 09:07 PM   #7
Default Re: Does it matter what order you put injectors in? (spnfed)
i know my question is and i think the guy that started this thread is, do certain injectors go in the certain spots of is it any injector in any spot
Old 03-04-2004, 09:13 PM   #8
b16ahybrid's Avatar
Default Re: Does it matter what order you put injectors in? (lsvtec hatch05)
It was already answered, The injector clips will only reach where they go. You cant cross them over to another cylinder. Also it doesn't matter if you take them out, juggle them for ***** and giggles and then put them back in, they have no specific order.
b16ahybrid is offline   Reply With Quote
Old 03-04-2004, 09:16 PM   #9
Louie_EM1
Guest
Posts: n/a
Quote:
I already stated that they are wired up.
My question is do injectors matter what location they are in; can you mix them up?
I searched but I couldn't find any info.
Shut the **** up
Don't try to be cute the question has been asked number of times.
It's comments like yours that are wasting people's times and bandwidth.
Quote:
Exactly.
Old 03-04-2004, 09:22 PM   #10
b16ahybrid's Avatar
Shut the **** up
Exactly.
Read my post! Or if you already read it, read it again.
Old 03-04-2004, 09:32 PM   #11
MrIllegalX's Avatar
I get what you're saying. The answer is no, it doesn't matter. It's actually better for you to switch them around from time to time. (While you're at it clean out all the gunk inside of the injector holes in the head, and the little filters on top of the injectors.)
MrIllegalX is offline   Reply With Quote
***How-To*** Install Valve Springs & Valve Stem Seals wildoutwhitegsr Acura Integra 165 05-05-2016 07:41 AM
Timing question for Z6 crank pulley. Ive searched and cant find an answer taytay Honda Civic / Del Sol (1992 - 2000) 23 12-08-2012 08:43 AM
k20a3 valve adjustment help b18LS Acura RSX DC5 & Honda Civic EP3 3 10-25-2011 12:19 AM
FS: 2005 AP2 CTSC parts / accessories (Intake system) s4play For Sale 1 09-14-2009 11:05 AM
what direction twenty Honda CRX / EF Civic (1988 - 1991) 5 06-11-2005 05:52 PM
Tags
civic, dose, fuel, gst, honda, injecters, injector, injectors, location, mater, matter, matters, order, piston, wired, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
