Do honda ECUs still use the o2 sensor if they are throwing a code 41?
Old 12-24-2005, 07:10 AM
dfn_doe's Avatar
Default Do honda ECUs still use the o2 sensor if they are throwing a code 41?
Just like the title says... I've recently wired a techedge wbo2 sensor into my ecu using the simulated narrow band output wired to the o2 signal wire of the ecu. The computer is throwing a code 41 (bad primary o2 sensor heater), is the ECU still using the o2 sensor signal for fueling corrections or does it disable the sensor? Also, I have a hondata s200, do I still have to use a resistor between the heater wire and ground to clear the code 41 or can I just disable the heater in the hondata software?
Old 12-24-2005, 08:09 AM
SVOboy's Avatar
I would guess (emphasis on guess) it still uses the input without the heater, and you should be able to disable the heater with hondata.
924drb20
12-14-2010 10:36 AM
vtec25
03-14-2006 02:39 AM
Eucalyptus lude
06-03-2005 01:42 PM
MRSI00
04-03-2003 07:26 AM
Quick Reply: Do honda ECUs still use the o2 sensor if they are throwing a code 41?
