distributor and head question - Honda-Tech
Old 06-08-2006, 01:13 AM   #1
milllllkman's Avatar
Default distributor and head question
I am trying to figure out which head is on this b18b block i have... I bought it from a friend of a friend and he said it was a b18b... I think the distributor is shot and i got a working one from a 95 ls and it wont fit.. the code on the head is pr4.. on the timing cover its in jap so i guess its a jdm head.. are the b18a 92-93 distribtors different then the b18b's? Thank you
milllllkman is offline   Reply With Quote
Old 06-08-2006, 03:21 AM   #2
project 2two9's Avatar
Default Re: distributor and head question (milllllk)
the b18a distributor should work on it
project 2two9 is offline   Reply With Quote
Old 06-08-2006, 05:33 AM   #3
deckster333's Avatar
Default Re: distributor and head question (project 2two9)
Use the distributor that goes with the OBD of your ecu and ignition system
deckster333 is offline   Reply With Quote
Old 06-08-2006, 10:35 AM   #4
Yeah thats the problem.. i got a 95 ls distributor right here obd1 and it doesnt fit.. i dont want to waste more money on another one thats not going to fit.
Old 06-08-2006, 11:08 AM   #5
Default Re: (milllllk)
How do you identify the distributor? Like tdxxx? The only writing i found was on the inside of the cap that said PT2/3 M16680
Old 06-08-2006, 12:30 PM   #6
ACURA INTEGRA 1.8L NON-VTEC
1996 - 2000 OEM # TD-85U (OBD2)
1992-1995 OEM #: TD46U OR TD55U (OBD1)
1990-1991 OEM #: TC07A, TD23U, & TD24U (OBD0)
that should be correct
Old 06-08-2006, 12:37 PM   #7
instructor74's Avatar
Default Re: (deckster333)
this might be stupid but did you check to see if you had the key way turned to match the cam? these are keyed to go in one way only.
instructor74 is offline   Reply With Quote
Old 06-08-2006, 01:20 PM   #8
PhatBoy5015's Avatar
Quote:
What do you mean by "doesn't fit"? What part of the distributor isn't fitting?
PhatBoy5015 is offline   Reply With Quote
B18A distributor doesn't fit B18B engine? Double Agent Acura Integra 8 09-23-2009 09:12 PM
ls distributor in b16 head? 1sikhatch Acura Integra 6 10-02-2005 07:18 PM
d16z6 throttle body and distributor on b18a lscoupe Hybrid / Engine Swaps 2 03-09-2005 09:16 AM
which is tach signal/tach wire - on distributor (obd-0) b18b ejectseat Acura Integra 3 01-16-2005 05:41 PM
will a 99-00 b16 distributor work on a 95 gsr head? Twenty36_1 All Motor / Naturally Aspirated 7 08-22-2004 11:21 PM
Tags
b18, cap, civic, difference, distributor, fitting, honda, m16680, obd, problems, pt23, td46u, td55u, td85u, tec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
