del sol - vent blower motor not working - Honda-Tech
Old 07-22-2011, 11:22 AM   #1
Default del sol - vent blower motor not working
i have a 94 del sol when i got it the ac worked fine but was disconnected at the fan.and now there is no air coming thru the vents on any setting.i turn the ac on and the fan turns on but still no air thru vents hot or cold.unless im in motion of course hot air creeps in.i bought a blower motor relay as the cheapest suggest ive heard but i don even know where it goes.
kap10apathy is offline   Reply With Quote
Old 07-22-2011, 12:49 PM   #2
Default Re: del sol ac trouble shooting
if anyone has any idea on how i can get some cold air in my car please its freakishly hot out an i literally cant drive untill night time and even then its still almost unbarable
Old 07-22-2011, 01:24 PM   #3
When you say fan, do you mean condenser fan in the engine bay or the blower behind the glove box. For the latter, have you checked the two blower motor fuses?
Former User is offline   Reply With Quote
Old 07-22-2011, 02:27 PM   #4
yes i do mean condenser fan.so there IS a third fan?i went thru and checked fuses under hood and in dash but where exactly are these fuses to be sure?and thank you for your feedback
Old 07-22-2011, 02:56 PM   #5
Quote:
The (1) condenser fan and (2) radiator fan sit next to each other under the hood. The (3) blower behind the glove box moves air out of the vents in the cabin.
I'm really confused because I expected you to say the blower doesn't work because you said that no air is coming out of the vents.
So the only problem is that the condenser fan doesn't work?
Old 07-22-2011, 06:34 PM   #6
oh ok i think i am in the right direction now since i only seen two fans i was lost.the radiator fan and condenser fan both work fine its the blower fan im probably having problems with.cause thats exactly the only problem no flow in the cabin (lol cockpit).fuse and/or relay placement?
Old 07-22-2011, 08:09 PM   #7
Check the two blower motor fuses (hood and dash).
Old 07-23-2011, 10:54 PM   #8
i checked,fuse 13 is fine.smelled like a blown fuse under my hood in that fuse box but i checked all the fuses they were all fine and none of the relays smelt burnt but i for sure smelled something,thinkin it was the blower i took my glove box out smellin round up there and still smelled nothin but its also 2am so what do i kno im goin to bed
Old 07-27-2011, 01:19 PM   #9
Default Re: del sol - vent blower motor not working
i dont know i assume that my blower burned out is this a difficult fix
Old 07-27-2011, 01:25 PM   #10
That's a good guess. Wire the motor directly to the battery to see whether it runs.
Old 07-27-2011, 06:40 PM   #11
redm3turbo's Avatar
pull the blower out....
check for leaves or a mouse nest....
redm3turbo is offline   Reply With Quote
Replaced Blower and resistor but not blowing hard enough. theheilious Honda Accord (1990 - 2002) 15 10-15-2016 07:29 AM
help help help ac diagnosis new_ek_owner23 Honda Civic / Del Sol (1992 - 2000) 4 07-04-2015 08:37 AM
'92 VX Blows weak Pooby88 Honda Civic / Del Sol (1992 - 2000) 4 06-08-2010 05:15 PM
AC blowing intermittently adand001 Honda Civic / Del Sol (1992 - 2000) 1 06-08-2008 02:23 PM
No heat or AC from my vents.....del sol digital sol Honda Civic / Del Sol (1992 - 2000) 3 08-07-2007 03:07 AM
Tags
94, ac, ai, air, blower, conditioner, conditioning, del, fan, honda, light, sol, troubleshooting, turning, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
