99-00 Si cluster into 96-98 ek
Old 12-13-2008, 07:30 PM
25ck5nah2's Avatar
Default 99-00 Si cluster into 96-98 ek
Hey guys, I just ran into some problem with my si cluster. When I plug the si cluster into my car, the temp and gas gauge doesnt work. Can you guys help me out? Thanks
Old 12-13-2008, 08:05 PM
slimjimming6688's Avatar
maby the gueage is broke, try drounding the temp sensor wire, the temp needle should go max hot
Old 12-13-2008, 09:04 PM
25ck5nah2's Avatar
drounding or grounding? I mean shouldn't the 99-00 si cluster be a plug and play into a 96-98 ek hatch? Both of my gas and temp arent working. The Rpm gauge and mph is fine though.
EDIT: My fuel and temp gauge works when I put in my original DX instrument cluster. When I installed the si cluster, it doesnt work at all.
Old 12-13-2008, 10:33 PM
Cuda's Avatar
^^ sounds like somethings wrong with the cluster.. it IS plug and play...
Old 12-14-2008, 07:51 AM
-Gambit-'s Avatar
if everything worked fine on your old cluster, everything should work with the si cluster, unless something is wrong with the si cluster.
Old 12-14-2008, 11:00 AM
DumpedSi's Avatar
make sure all the screws are on the back of the si cluster. If any of them are missing it could cause things to malfunction
Old 12-14-2008, 11:44 AM
m3tech95's Avatar
worst case scenario, take out the housing & swap face plates// i had that problem previously i just swapped them, they are basically the same thing just different face plates....g/l
Old 12-14-2008, 02:30 PM
kulo's Avatar
wont the si dials plugs straight into the 96-98 ek shape?
Old 12-14-2008, 03:57 PM
25ck5nah2's Avatar
nvm i figure out the problem. I swapped my Si Temp/Fuel gauge with my friend's EX Temp/Fuel gauge to test it out, and turns out that I need a new gauge! Well the Si temp/fuel gauge that is. Only 28 bucks from honda so ima just order it from there. Thanks for the help guys.
Old 12-14-2008, 04:08 PM
raidacaipo's Avatar
something is wrong with the si cluster..
97_Ek
03-13-2008 08:55 PM
GreddyCivic7
26
04-11-2007 03:38 PM
137
10
04-22-2004 12:58 PM
labatia
01-07-2004 12:01 PM
Mr Boston
09-06-2003 10:00 AM
Quick Reply: 99-00 Si cluster into 96-98 ek
