del sol map lights?
del sol map lights?
i got some del sol map lights installed them then noticed my door wont open lol ,
do i need to have the jdm rods as well or is there anyway to make them work with the stock u.s rods?
Re: del sol map lights?
Yes, you can use the stock door cables but it is kind of a pain to get them to function properly on a consistent basis. I connected two small metal clips to the stock door cables to get the proper tension on them to open the doors. The setup worked quite well for a couple of years until I purchased the JDM door rods.
If you decide to try and use the stock cables, you'll probably have to experiment with something to get it to work. It's a lot less headache if you can just find someone selling the JDM rods.
I'll pm you a possible source that might be able to get you just the rods or you can check ebay.
b184life
07-09-2012 06:12 PM
revvin9k
07-17-2004 12:51 AM
