Del Sol - main bearing in S20 transmission going out
I just picked up a 95 Del Sol S. I love it and it is my new project car. My basic question is the main bearing in the S20 transmission is going out. It has a D15B7 that is stock and running strong for 187k on it. Should I pull the tranny and have it rebuilt, and put a D16z6 or y8 head on and mini me it. Or should I do a whole Engine and tranny swap to a D16z6?
Thanks
Thanks
Seagull Management
Re: Need help with a plan
Input shaft bearing on one of those is worth about $20, figure in another $5 or so for the seal that goes under it, do the labor yourself and you're only in it for $25 (there are a couple of other bearings in that that you should look at, but chances are you'll be well under $100.
Well what do you want from this car? Tons of power? Maybe a little pep and a nice oem/jdm look? I mean if its a project...and you're wanting any kind of pep/power you will need to rid of the B7! Z6/Y8 is a good SOHC...I'd rather just find a full swap rather than a mini-me...what about B series?
94EG8 Thanks I think that is what I will do with the trans if I stay D series. I did pick up a used S40 trans but then I learned the gear rations in the S20 are better so I rather just rebuild.
hannslebo I would like a B16 the issue is cost I can't find any decent priced B16's I keep finding D16Z6's rebuilt for $800.
Seagull Management
I don't want this to turn into big flame fest or anything, but B16s are overrated, even in a CX hatch they're still torqueless, they don't feel any different than a Z6 until about 5000rpm. A B18C GS-R is a far better choice IMO.
I am putting off engine plans for now. Decided to build up the steering and front end. My plan now is to build from the ground up. Meaning suspension and steering first.
97dssi
03-27-2011 12:34 PM
Its Stock I Swear
08-23-2005 10:11 PM
