Default Difference Between ZEX 105300 and Crower Stage 2 NA
Hey guys, I need some technical perspective here. I have a Crower Stage 2 NA cam currently in my D16y8. I'm converting the motor to be a mid boost setup. I'm looking for ~300whp, and the motor will probably see about 14psi, and rev to about 8000rpm.
It's been recommended by many that I swap out my NA cam for a ZEX 105300. Most boosted D builders swear by the ZEX cam; however, from the specs I've seen, it's not much different than the Crower Stage 2 NA cam.
Here are the specs from both manufacturers:
http://www.crower.com/cat/impo...shtml
http://www.zex.com/Products/Va...s.asp
Can somebody with some cam knowledge explain to me why the ZEX cam would be better for mid-boost than the Crower Stage 2 NA cam? I'm primarily looking for technical responses with references to the specs on each cam, but I'm also open to opinions of what you guys think is the best cam for a boosted D16y8.
Exospeed, if you'd like to chime in, I'm also considering a custom cam from you. Let me know what my options are with Exospeed.
Thanks in advance!
Thanks in advance!
xkrazyxjbrkerx75
11-04-2009 10:48 PM
ridin98civic
18
05-11-2007 04:38 AM
chadalac1712
05-10-2007 06:43 AM
