d16z6 weird idle
d16z6 weird idle
ok when i start up my car it idle high and warm up fine.. then idle drop too normal... but when i drive it sometimes the check engine light come on.. when i stop.. the idle drop real low.. but car doesnt stall.. it feel like it wanna stall.. but then when i drive off for a while and stop again.. idle goes back too normal... does anyone know what could be causing this.. thanks in advance..
Re: d16z6 weird idle (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">for starters, check what the cel shows</TD></TR></TABLE>
X2!!!!!
I think if you adjust the idle screw a tad it may make the problem better, if not solve it entirely...but def. figure out the CEL.
X2!!!!!
Honda has a bad electrical set up also i had that problem and i put 10.2 spark wires on and it doesn' t happen no more also the o2 sensor is bad i would replace that first
the ecu code was 22... vtec was clogged up.. everything is fixed now.. no more check engine and vtec crack hard now.. iam gonna change o2 sensor anyways too be on the safe side since it look pretty dirty.. thanks everybody
Re: (EGfosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho »</TD></TR><TR><TD CLASS="quote">u mean the vtec silenoid was clugged up?</TD></TR></TABLE>
Yeah I think that's what he's saying.
Don't see how that caused a fluctuating idle problem though.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Don't see how that caused a fluctuating idle problem though.</TD></TR></TABLE>
STFU!/\/\/\/\
code 22 check the solenoid ground,
idle problem? IDLE AIR CONTROL VALVE or FAST IDLE VALVE
STFU!/\/\/\/\
Re: (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 »</TD></TR><TR><TD CLASS="quote">
STFU!/\/\/\/\
</TD></TR></TABLE> Hahahahahaha... He's gotta chime in on everything doesn't he?
STFU!/\/\/\/\
