Skunk 2 Pro Series Coilovers
Old 06-09-2007, 09:44 AM
irideslammed5021's Avatar
Default Skunk 2 Pro Series Coilovers
Just got my skunk 2s, the front is the fork type that the bolt sits through the lower control arm and the rear is the type that sits in the lower control arm, did they send me the wrong coilovers? i just cant figure it out
Old 06-09-2007, 10:01 AM
94hatchling's Avatar
Default Re: Skunk 2 Pro Series Coilovers (irideslammed5021)
i think you have those two backwards....
the pair with the fork already on them go on the rear.
the pair that sit into the factory fork that go around the axle, go up front.
clearer now?
Old 06-09-2007, 09:55 PM
New User
Racing rice's Avatar
Yeah, what he said. If you need any help with the install let me know. My didn't come with directions so it was a bit odd, a couple of suggesions..
1 - Cut off the two smallest rings in the bump stop.
2 - Use this order when installing your top mount (from top to bottom: Install starting from the bottom.)
:Nut
:Gold washer
:Bushing - big side down (bushing tube will connect the two bushings)
:Top mount
:Bushing - Big side up
:silver tapered washer
:bump stop
Hope that makes sense. If the ride feels bouncy, make sure that you aren't TO low, if you are two low then you have no suspension travel and are bouncing off of the bump stop.
Jdub4242
07-02-2015 02:21 PM
Phantom240
Honda CR-V & Element
12
07-11-2013 08:35 AM
CubbyChowder
05-06-2010 01:50 PM
boraVr
12-01-2007 08:56 PM
Red_Si
06-25-2003 09:41 AM
Quick Reply: Skunk 2 Pro Series Coilovers
