D16Z6 Valve Adjustment
Old 10-23-2009, 09:47 AM
jdmsir4dr's Avatar
Default D16Z6 Valve Adjustment
im wondering how do i kno if i need a valve adjustment .my boy told me dat i need one becase when u have the hood open and listen clearly u hear like a tinking noise but its not real loud its low..i think its cuz it has headers any help
Old 10-23-2009, 09:57 AM
boxeocampeon's Avatar
Default Re: D16Z6 Valve Adjustment
could also be a blown head. u have an white smoke coming out the exhaust or any oil in your coolant?
Old 10-23-2009, 10:09 AM
jdmsir4dr's Avatar
no oil in the coolant..no white smoke besides when u turn on the car in the am to warm it up
Old 10-23-2009, 10:48 AM
Rok_Stok's Avatar
When I had a z6 my valves ticked. So I adjusted them and it went away. It's one of the easiest engines to adjust valves on. The end.
Old 10-23-2009, 12:29 PM
jdmsir4dr's Avatar
good looks i guess ama bring it to the shop to do dat
Old 10-23-2009, 01:15 PM
Rok_Stok's Avatar
Or get some vice grips, a 10mm deep socket, a flathead screwdriver, feeler gauge set, and do it yourself. There are write-ups all over the internet how to do this. Save your money and get smarter about cars.
Old 10-23-2009, 04:43 PM
okay sounds like a valve adjustment then
Old 10-23-2009, 04:56 PM
gen2tegboi's Avatar
Click here
Old 10-23-2009, 05:50 PM
HiProfile's Avatar
If they are loose, you are loosing power since your valves aren't opening up 100%. You'd see better power, less vibration, and better gas milage. Less noise is a fringe benefit...
If you're not that skilled with motors, you may want to take it in. It's not hard, but neither is overtorquing and snapping a lifter. Not a fun thing to fix.
Old 10-23-2009, 08:20 PM
Rok_Stok's Avatar
That's true, instead of making 100whp you could be making 101whp. Good point.
Old 10-23-2009, 08:28 PM
lastresort576's Avatar
Make sure when you do this the engine is completely cold otherwise it wont be accurate.
Old 10-24-2009, 01:52 PM
tito87's Avatar
Think I'll be needing to adjust mine as well.
rondogg779
10-28-2019 11:19 PM
lazyxmofo
05-23-2012 07:04 PM
2hondas_noluck
12-20-2010 05:52 PM
Caveman74
09-18-2010 02:46 PM
Quick Reply: D16Z6 Valve Adjustment
