D16Y8 upgrade path
Old 03-06-2008, 08:19 AM
CivicExMaster's Avatar
Default D16Y8 upgrade path
Does anyone have ay good upgrades for a stock d16y8. got the intake already, but didnt know if anyone did upgrades they are happy with like (intake manifold, ignition. etc.) if anone has any good upgrades let me know
Old 03-06-2008, 08:39 AM
96 EX's Avatar
Default Re: D16Y8 upgrade path (CivicExMaster)
Your best bet with the Y8 would be to turbo it... other than that anything is pretty much pointless. You could also do a swap to a DOHC whether its VTEC or not still would have more potential then the Y8. Also you should try using that red button in the top right hand corner called "Search". Hope this helps!
Old 03-06-2008, 10:05 AM
spotscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet with the Y8 would be to turbo it... other than that anything is pretty much pointless. You could also do a swap to a DOHC whether its VTEC or not still would have more potential then the Y8. Also you should try using that red button in the top right hand corner called "Search". Hope this helps! </TD></TR></TABLE>
pretty much right. the only way your going to feel anything at all would be to boost it. but if you want low maintence go with a b-series NA.
byarbroo
10
12-03-2012 09:40 PM
v8killa91
07-18-2006 03:06 PM
awdriscol4
28
03-05-2005 10:13 PM
Jaysun
09-24-2003 10:33 PM
btlfedhatch
16
07-05-2002 10:16 AM
Quick Reply: D16Y8 upgrade path
