d16y8 tuning issues
Old 09-07-2005, 05:46 AM
dsdonnie's Avatar
Default d16y8 tuning issues
I just got done putting in this setup into a y8:
-a new ported/polished head
-Crower stage 1 cam(z6)
-Skunk2 Intake Manifold
-Skunk2 cam gear (y8)
-Crower Stainless Steel Valves
-Crower Titanium Ret. and Valve springs
-AEM Fuel Rail
-B&M fuel pressure reg. (turned up to 45)
Ok now I am having some issues. it doesnt seem to pull hard at high speed. I have a Z6 crower cam but its a y8 motor. Crower said to advance the timing 6 degrees because of the combo to run right. we did that but i am wondering if they were off and I should advance it more. I can advance it up to 10 degrees.
Anyone have any insight?
Old 09-07-2005, 05:52 AM
civicholo's Avatar
Default Re: d16y8 tuning issues (dsdonnie)
i would try to do just that. advance it a little more to see what it does. you're "tuning" it. also be sure the valves are all adjusted right and everything is tight. because you have a port and polish job might have an effect on it too. from what i know, that is supposed to add hp not trq. by the way, i have the same head on my d15b block. all i need is a vtec controller to activate the vtec. good luck.
Old 09-07-2005, 06:30 AM
dsdonnie's Avatar
Default Re: d16y8 tuning issues (civicholo)
yeah it did increase overall HP. i am concerned with valve clearance issues by advancing the timing too much.
Old 09-07-2005, 08:20 AM
gftgrill's Avatar
I have a stock y8 with the crower stg1. it has good pull throughout. I had to advance timing pretty far to get it to idle. but before I had it advanced so far, it had great pull.
so try retarding your dizzy a little and see if that gets you what you want.
Old 09-07-2005, 11:14 AM
dsdonnie's Avatar
Default Re: (gftgrill)
It was originally set and "0" and ran like *** and wouldnt idle. I had to advance it to "6" and it idles fine but not what I would expect from a built d16y8 minus the bottom end. i still cant get over how loud it is. i also put my silencer back in and it seems to run even better with it in for some reason. but it still doesnt have as much top end as i would expect. the comp cam guys dont know anything and have been no help.
Old 09-07-2005, 11:51 AM
gftgrill's Avatar
ok, try setting your cam gear to about 4.5 instead of 6.
technically the z6 and y8 are a half tooth apart, which is 4.75 degrees. I have a z6 adjustable gear on my y8, and I have it advanced or retarded, I forget which, so I set it between 4 and 5 degrees.
but I had to advance the ignition timing pretty far to get it to idle. remember that ignition and cam timing are different. when my ignition timing was at stock, it wouldn't idle for ****, but damn it felt great on the highway.
Old 09-07-2005, 06:20 PM
dsdonnie's Avatar
i didnt know you could adjust your ignition timing
Old 09-07-2005, 06:35 PM
Bond's Avatar
Default Re: (dsdonnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsdonnie &raquo;</TD></TR><TR><TD CLASS="quote">i didnt know you could adjust your ignition timing</TD></TR></TABLE>
Just get a timing light and rotate the dizzy forward (advanced) and back (retarded). Adjusting the ignition timing will help a lot with your tuning. they could be very right about 6 degrees advanced and you just have to set your ignition timing now.
Old 09-08-2005, 11:00 AM
dsdonnie's Avatar
Default Re: (Bond)
dizzy?
Old 09-08-2005, 11:04 AM
gftgrill's Avatar
dizzy = distributor
Old 09-08-2005, 11:07 AM
gftgrill's Avatar
Default Re: (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">
Just get a timing light and rotate the dizzy forward (advanced) and back (retarded). Adjusting the ignition timing will help a lot with your tuning. they could be very right about 6 degrees advanced and you just have to set your ignition timing now.</TD></TR></TABLE>
just so you know how to do this. there are 3, 12 mm? bolts holding on the dizzy. just loosen them a little and rotate as needed, don't remove the bolts and don't overtighten. it might be a good ideal to use a sharpie and mark the dizzy before moving it so you know where you started at if you need to reset timing
advanced = turning the dizzy towards the firewall
retarded = turning towards the radiator.
Old 09-08-2005, 12:24 PM
dsdonnie's Avatar
ok i appreciate the info. I never heard of that before. I didnt you could adjust the ignition timing that way
Old 09-08-2005, 12:35 PM
q45mm's Avatar
HE's right
Old 09-08-2005, 05:06 PM
dsdonnie's Avatar
Default Re: d16y8 tuning issues (q45mm)
any other tuning tips from anyone to get this running better?
Old 09-08-2005, 07:45 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsdonnie &raquo;</TD></TR><TR><TD CLASS="quote">any other tuning tips from anyone to get this running better?</TD></TR></TABLE>
Well make sure the O2 sensor(s) are working and get an adjustable FPR so you can fine tune a little more. Also check and adjust your idle too.
Old 09-08-2005, 07:48 PM
Hyjnx's Avatar
how much did that all cost u? and is it a large difference over stock? i was thinkin about some of those mods myself and i wanted to know if u felt it was worth the money
Old 09-09-2005, 05:16 AM
dsdonnie's Avatar
Default Re: (Hyjnx)
I am not sure on the exact cost as I got a hell of a deal on the head. I paid 350 with all the internals in it from crower. the internals alone cost more than that. I paid 1300 for the labor plus new timing belt,waterpump,intake manifold,cam grar,fuel rail and regulator(got these for $125). All in all I eneded up spending around 1500-1600.
As far as a power difference it still needs some tuning but overall a pretty nice increase but LOUD. Then engine is twice as loud.
Old 09-09-2005, 07:17 AM
Hyjnx's Avatar
damn thats nice...i know people that could do the labor i jsut wanted to know about the other products...my guess is u dropped it all in at once so u didnt see the significance of each product...still thats cool...definately would like to check that out
Old 09-09-2005, 10:45 AM
dsdonnie's Avatar
Default Re: (Hyjnx)
I am hoping to get some decent #'s but I think I may need to jump up to a stage 2 cam. If i still see the same results after next week I am gonna get the stage2 I think.
E_F_9
02-03-2010 02:59 PM
E_F_9
01-19-2010 07:38 PM
lilsicsoul
03-02-2009 08:55 AM
EJ8tunerman
04-03-2007 09:38 PM
walsh22
12-12-2006 05:59 PM
Quick Reply: d16y8 tuning issues
