D16Y8 - Timing belt replacement?
Met a new friend the other night and I wanted him to double check the ignition timing since I just replaced the distributor. Well, long story short he wasn't able to time it perfectly since the belt jumped a 1/2 a tooth or 1 tooth.
The motor has around 90k on it, so i figure it's time to replace the few parts anyways (timing belt, water pump and tensioner).
He told me just go OEM and hondaautomotiveparts.com would be the best to order from online.
Problem is, I don't know which parts to order. I saw two diffrent belts to pick from and wasn't sure which to get. Also saw like 3 diffrent tensioner's.
Just trying to figure out which is the correct stuff so I only have to order it once!
-Mike
-Mike
Re: D16Y8 - Timing belt replacement?
Gates TCK224 Timing Belt Component Kit is $40 (free ship) from amazon.com. It's the timing belt and the tensioner in one set. I'm running it on a B16A2. Gates is just as good as OEM and you can't beat that price.
-Mike
-Mike
Nah, I don't have a VIN to go by. It's not the original engine in the car, came from a '97 civic ex. I think I read somewhere the VIN is on the engine too, so I guess I could look for it and use it on mejestic's site.
Ok that sounds great, you sure that one will work with the d16y8?
Former Moderator
If it's my car, and I'm doing a timing belt I'd replace the following - OEM part numbers are listed, along with who makes them for Honda and alternative makes that are good.
Timing belt - 14400-P2F-A01
Unitta makes the actual Honda branded belt for the 96-00 Civic EX. Other great alternatives are Gates, Bando, or Mitsuboshi. Any of these should be readily available even at generic parts stores, so please don't buy some crap Goodyear or other truly off brand T-belt. Gates does supply Honda with some timing belts too.
Alternator belt - 31110-P2A-004 (4PK800)
Mitsuboshi or Bando makes the OEM Honda belt here. Either can be found easily enough, and cheaply enough.
A/C belt (if applicable) - 38920-P2A-003 (4PK820)
P/S belt (if applicable) - 56992-P2A-003 (4PK850)
Water pump - 19200-P2A-A01
This is the tricky one. Otsugi makes the actual genuine Honda waterpumps, and they are an unknown brand amongst the local parts store types. I' have seen a lot of different brand water pumps, and the closest thing to the Genuine Honda/Otsugi water pump is the Paraut or Aisin brands, and nothing else.
Cam seal - 91213-P2F-A01
NOK or Arai Seisakusho makes the Genuine Honda seals. Do not get aftermarket brand seals. I'd score these from your local Honda dealership if you cannot find them online.
Crank seal - 91212-P2F-A01
Timing belt tensioner - 14520-P2A-305
NSK makes the Genuine Honda tensioner here. They can be found cheaply enough online at just under $20.00. I'd steer clear of other brands if possible.
Coolant (kind of impossible not to change since it all comes out when you pop the water pump off the block)
You can search Majestic Honda's site using the provided part numbers as they are correct for a 1997 Civic EX with D16Y8 engine. The only differences would be the P/S belt (if you have it) depending on what pump you're using. Everything else should be the same, regardless of the chassis.
Former Moderator
BTW here are some helpful diagrams for you.
Timing marks to check timing belt timing:
Timing marks at crank gear (with crank pulley removed)
Close up of cam gear timing marks:
Timing components:
Proper timing belt routing:
Timing components:
Wow! Thanks for that.
I called the dealer earlier this morning and the prices where crazy, the water pump and tensioner where around $90 a piece.
I just ordererd the timing belt, water pump, tensioner, etc... and all the gaskets and seals for my y5 and I went through the dealer because the parts manager gives me wholesale prices and is actually quite comparable to majestic's but without the shipping. Well last time I spent just over $400 and he turned it over to one of the other guys... needless to say in the end I didn't get a discount and could've saved $120 and had paid the shipping from majestic... never again.
the shipping is kinda high so when I order I usually try to make it worthwhile and order more than just a couple of items.
the dealer did give me wholesale prices so I can fix my front end on two fenders, bumper cover, bumper reinforcement bar, headlight, fender liner & clips and they did really good that time for me. I've prob. spent at least $1500 there just this year in parts, I never got service there unless it was still under warranty.
You should buy the OEM water pump. I paid 80 for mine. 90 isn't far off. They might give a discount for AAA members and call other dealers.
imadigitalgod
08-18-2023 08:01 PM
