99 civic no spark after coil.
Old 02-15-2017, 08:57 AM
Erik Nielsen's Avatar
Default 99 civic no spark after coil.
I read a forum on the no spark issue and performed the tests within the link. It stated that if you have spark at the coil and the rotor turns then replace the cap and rotor. I did that and I still have the same problem no spark out of the cap to the wires. Any suggestions for a cure?
Old 02-15-2017, 06:50 PM
prodjay10's Avatar
Default Re: 99 civic no spark after coil.
How you testing for park at the coil. It might be that the spark is not strong enough.
Old 02-16-2017, 04:39 PM
tamboo's Avatar
did you use a high energy ignition spark tester? (dirt cheap on ebay)
if not you may have damaged the coil.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
jefflopez
03-21-2017 04:45 PM
Erik Nielsen
02-15-2017 05:07 PM
wellssc2002
11
02-02-2016 02:46 PM
gottagofaster
10-22-2005 04:50 PM
Quick Reply: 99 civic no spark after coil.
