D16y8 Engine Coolant Temp Sensor broke off - Honda-Tech
Old 04-19-2009, 04:51 PM   #1
tedo2007's Avatar
Default D16y8 Engine Coolant Temp Sensor broke off
Any easy way to get it out? its the one that sends the info to the comp.
Its broke right at where the thread ends, guessing previous over busted it off tigning it down to much...went to replace and found it busted....
tedo2007 is offline   Reply With Quote
Old 04-19-2009, 06:11 PM   #2
tedo2007's Avatar
Default Re: D16y8 Engine Coolant Temp Sensor broke off
no ideas?
Old 04-20-2009, 12:56 AM   #3
boostatic's Avatar
if im thinkin correctly the housing comes right off..the same housing for the thermostat..take the housing off and replace it with another one..or take it off and a shop should be able to get it out for you if you cant do it yourself..
boostatic is offline   Reply With Quote
Old 04-20-2009, 05:17 AM   #4
Davus's Avatar
Unfortunately it's not on the thermostat. The fan switch is, but ECT is around the upper radiator hose.
Have you tried "locking pliers" yet to grab the remainder of the sensor?
Davus is offline   Reply With Quote
Old 04-20-2009, 03:23 PM   #5
tedo2007's Avatar
it basically broke clean off level with where it screws in at....maybe an easy out?
Old 04-22-2009, 06:12 PM   #6
tedo2007's Avatar
nobody/
Old 04-26-2009, 10:52 AM   #7
tedo2007's Avatar
any possibly way to get this out without causing major damage or having to remove head?
Old 04-26-2009, 12:37 PM   #8
NHB
NHB's Avatar
Quote:
Worth a try. If it sheared off from an over-torque as opposed to corrosion, it should be removable this way...Just be careful and use high quality metal bits, driven pneumatically if you can. Last thing you want is to get into the sensor and then break a drill bit tip off in your new hole. Go slow don't harden the metal.
NHB is offline   Reply With Quote
Old 04-28-2009, 06:12 PM   #9
tedo2007's Avatar
according to prev. owner, he broke it off putting the new one in....so thats whats its gotta be from, which easy out should i use? ive seen several....let me know ill ill buy it!
98 civic jumping speedo nokehockey20 Tech / Misc 2 07-07-2016 09:43 AM
busted foglight!!! pacifico Honda Civic / Del Sol (1992 - 2000) 9 09-29-2005 05:40 PM
Intake Manifold Problems. I Need HELP! silverstreak20 Acura RSX DC5 & Honda Civic EP3 12 03-21-2004 03:18 PM
HELP busted wheel lock? b00stedsi Tech / Misc 2 05-16-2002 07:38 PM
Aw Crappppp, I broke my wheel lock key 97ITR Acura Integra Type-R 9 03-24-2002 06:24 PM
Tags
acuraintegra, broke, d16y8, del, fan, honda, location, prelude, radiator, sensor, sol, switch, temp, temperature, yourself
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
