D16Y7 engine with D16Y8 tranny
would the D16Y8 tranny do something if a put it in the D16Y7 engine and what difference would it make if i drop the vtec head also with the tranny
Re: D16Y7 engine with D16Y8 tranny (lmiguelvv)
if you put the y8 tranny on a y7 motor then all you will have is a DX with shorter gears. If you put a y8 head on the y7 motor that will make it cool and a bit faster. I hear it only makes about 10 horse more than a stock EX would make.
But everything bolts up. Good luck.
Re: D16Y7 engine with D16Y8 tranny (MikeNice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote"> I hear it only makes about 10 horse more than a stock EX would make.
But everything bolts up. Good luck.</TD></TR></TABLE>
are you saying that a y7 block witha a y8 head makes 10hp more than a y8 block and head?? if that was right, the mini me would make like 137 (not wheel)hp. for some reason that doesnt sound right but i could be wrong
How would a mini-me have more Hp than a stock Ex??
Bolting on a Y8 tranny to a Y7 block is an EXCELLENT upgrade on its own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote">if you put the y8 tranny on a y7 motor then all you will have is a DX with shorter gears. If you put a y8 head on the y7 motor that will make it cool and a bit faster. I hear it only makes about 10 horse more than a stock EX would make.
you have no idea what you are talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmiguelvv »</TD></TR><TR><TD CLASS="quote">but if i put the ex vtec head and the tranny would it make a difference than just the ex tranny on it</TD></TR></TABLE>
Well....of course it would help.
Slapping on a tighter geared tranny will help you accelerate a bit quicker; slapping on a VTEC head would increase tq/hp which would also help you accelerate quicker.
Re: D16Y7 engine with D16Y8 tranny (EE_Chris)
y7 with a y8 head doesn't make more power than a standard EX. this is because EX has diffrent piston and compresssion rate.
Re: D16Y7 engine with D16Y8 tranny (atermizi)
true, personally i have a y7 with a y8 head and a y7 tranny but am going back to the stock y7 head and slapping on the y8 tranny for some more fun, the y7/y8 minime has too many freaking sensors that it is looking for
Risky Business
Re: D16Y7 engine with D16Y8 tranny (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">true, personally i have a y7 with a y8 head and a y7 tranny but am going back to the stock y7 head and slapping on the y8 tranny for some more fun, the y7/y8 minime has too many freaking sensors that it is looking for</TD></TR></TABLE>
B7/Z6 ownz j00!!!!
But yeah to the thread starter, a Y7 with a Y8 tranny will feel 10x better than stock, and if you throw a more aggressive cam in there it will feel even better than a Y8
B7/Z6 ownz j00!!!!
Re: D16Y7 engine with D16Y8 tranny (SOHC_MShue)
Assuming that the online CR calculators are correct, a y7 block w/y7 pistons + y8 head will yield a higher CR than a stock y8 setup. So makes sense that a y7/y8 mini-me will make slightly more power than a stock y8.
Re: D16Y7 engine with D16Y8 tranny (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
B7/Z6 ownz j00!!!!
very true, in fact obd1 ownz obd2
B7/Z6 ownz j00!!!!
anyone with a dyno of a minime jump in anytime....
I'm fairly knowledged about this, and a y8 tranny and head will make a large improvment. I would deffinatley do it. then go turbo. lol
Re: (MrIllegalX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrIllegalX »</TD></TR><TR><TD CLASS="quote">anyone with a dyno of a minime jump in anytime....
I'm fairly knowledged about this, and a y8 tranny and head will make a large improvment. I would deffinatley do it. then go turbo. lol</TD></TR></TABLE>
i did the y7 y8 minime then turboed, going back to the y7 head because of obd2 crazy codes
Re: (rexandfx)
Bump.....
Fixed your sensor problems at all?? Or are you still going back?
Re: D16Y7 engine with D16Y8 tranny (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">Assuming that the online CR calculators are correct, a y7 block w/y7 pistons + y8 head will yield a higher CR than a stock y8 setup. So makes sense that a y7/y8 mini-me will make slightly more power than a stock y8.</TD></TR></TABLE>
This statement is correct
Re: (rexandfx)
im gonna wire up the knock sensor soon, but i havent gotten a clear answer on ht about the fuel tank pressure sensor, i think you need to switch out the whole damn gas tank and charcoal canister and aslo acquire a purge solenoid, either that or wire in a resistor to trick the ecu
Re: (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">im gonna wire up the knock sensor soon, but i havent gotten a clear answer on ht about the fuel tank pressure sensor, i think you need to switch out the whole damn gas tank and charcoal canister and aslo acquire a purge solenoid, either that or wire in a resistor to trick the ecu</TD></TR></TABLE>
So what about swapping the ecu?? And if it would help, which one would you swap to?
enough said...
enough said...
99hatch
07-01-2004 01:20 PM
