D16Y7 ECM.PCM connectors.
Old 01-02-2010, 06:00 AM
S117A47's Avatar
Default D16Y7 ECM.PCM connectors.
So ive been searching around the site and alas, have not found anything. My 97 Civic LX threw P0441 at me and im trying to diagnose it. It says to jump the A10 and A15 terminals on the ECM/PCM connectors, however, im not sure which these are. Please halp! Thanks!
Old 01-02-2010, 07:17 AM
S117A47's Avatar
Default Re: D16Y7 ECM.PCM connectors.
ttt
Old 01-02-2010, 09:21 AM
S117A47's Avatar
Bump
Old 01-02-2010, 11:46 AM
S117A47's Avatar
Halp bump
Old 01-02-2010, 12:33 PM
Anon51's Avatar
P0441 Evaporative Emission (EVAP) Control System Incorrect Purge Flow
just check the purge solenoid.
Old 01-02-2010, 03:29 PM
S117A47's Avatar
I have the map for the diagnosis. I have already checked the solenoid and the connector. They are fine. The next thing would be to check the ECM/PCM connector d. I have to jump terminals a10 and a15. However none of the plugs match the wiring diagram that came with the diagnosis map. So what I am asking is where is connector d?
Old 01-02-2010, 03:52 PM
Anon51's Avatar
one of my favorite sites.
http://ff-squad.com/technet/wiring.obd2a.htm
Old 01-03-2010, 05:45 AM
S117A47's Avatar
Whoops i guess i neglected to tell everyone its an a/t. Sorry. lol. I didn't find anything like that for an a/t on the website. its all m/t...
Old 01-03-2010, 05:51 AM
Anon51's Avatar
i guess you didn't read the site.
"The blank connector (B) is only used with civic/integra vehicles equipped with A/T."
everything else pretty much is the same. you'll just be missing the C plug if i'm not mistaken. A/T's have A, B, D.
Old 01-03-2010, 09:04 AM
S117A47's Avatar
I read that part but I got confused because I looked at all of my plugs... They read A A A B, in that order. There is no C or D connector. Am I just looking in the wrong spot? I'm looking at the four plugs on the bottom of the ECM...
Old 01-03-2010, 10:32 AM
S117A47's Avatar
TTT
Old 01-03-2010, 01:47 PM
Anon51's Avatar
dude look at the pic. each plug is different length with diff color wires. in the pici linked. Pin A10 = power ground and A15 = purge solenoid. if you still can't figure it out check out the color of the wires at that plug.
D-seriousBis
04-11-2013 05:07 PM
TopEndTuner
Engine Management and Tuning
10-04-2008 04:58 PM
Malakai
14
12-19-2007 10:35 AM
SOFLSOL
09-03-2003 06:53 PM
B18C-RnVA
09-05-2002 01:37 PM
Quick Reply: D16Y7 ECM.PCM connectors.
