D16y7 to D16z6
Old 09-17-2008, 08:10 PM
93accordsleeper's Avatar
Default D16y7 to D16z6
Can I use my D16y7 distributor on a D16z6 head? trying to do the Mini Me swap in my 97 LX wit a D16z6 head
Old 09-17-2008, 11:10 PM
EGhatchguy's Avatar
Default Re: D16y7 to D16z6 (93accordsleeper)
no you need the distributor for that head or there will be no vtec..
Old 09-18-2008, 05:11 AM
nub
nub's Avatar
Default Re: D16y7 to D16z6 (EGhatchguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatchguy &raquo;</TD></TR><TR><TD CLASS="quote">no you need the distributor for that head or there will be no vtec..</TD></TR></TABLE>
The distributor doesnt control vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93accordsleeper &raquo;</TD></TR><TR><TD CLASS="quote">Can I use my D16y7 distributor on a D16z6 head? trying to do the Mini Me swap in my 97 LX wit a D16z6 head</TD></TR></TABLE>
yes you can. I have a y7/z6 using the y7 dizzy. However it doesnt bolt right up. I had to modify the tabs for the mounting bolts on the diz housing. Running a p2p and vtec engages fine.
Old 09-18-2008, 05:29 AM
llaco4life's Avatar
In my opinion i'd rather get the D16z6 distributor instead of having to modify any bolts. Just not one of the things I would mess with!
Old 09-18-2008, 04:32 PM
Default Re: (llaco4life)
well what do I have to do with the plugs? the Z6 is obd1 were the Y7 I can just plug and play
Old 09-18-2008, 06:17 PM
nub
nub's Avatar
Default Re: (93accordsleeper)
You could get a conversion harness or repin the z6 into the y7 plug. Or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote"> modify the tabs for the mounting bolts on the y7 diz housing.</TD></TR></TABLE>
Old 09-18-2008, 06:23 PM
Seagull Management
94EG8's Avatar
Default Re: (nub)
Or better still swap the guts out of the Y7 distributor into the Z6 case. I've done this between D15B7 and D16Z6 distributors before. I'm 99.9% sure that everything inside the OBD2A distributor is the same as the OBD1 versions.
Old 09-18-2008, 06:25 PM
nub
nub's Avatar
Default Re: (94EG8)
It all boils down to how do you want to skin your cat.
Old 09-18-2008, 06:59 PM
Default Re: (nub)
Nail its head to a tree, cut all the way around its neck, grab a hold and pull down, there u go skinned cat! But swapping the guts sounds good if that works, thanks for the info guys
JJDd16z6
09-21-2011 01:44 PM
VnZo
12-25-2009 01:27 PM
mizzoEG
11-13-2007 05:06 PM
thenick
09-25-2004 07:20 AM
-[95cxhatch]-
12-16-2003 06:46 PM
Quick Reply: D16y7 to D16z6
