d16y7 block with y8 head?
Old 10-04-2011, 10:41 AM
liljukmoves's Avatar
Default d16y7 block with y8 head?
i have a 97 lx with a d16y7 non vtec motor and i'm wondering what it would take to swap for the y8 sohc vtec head. should i? is it a good idea or benificial? and ill need a y8 computer too correct?
liljukmoves is offline
Old 10-04-2011, 10:48 AM
barrett_5's Avatar
Default Re: d16y7 block with y8 head?
been done lots. called a mini me swap. good idea yes, beneficial yes, y8 computer yes.
barrett_5 is offline
Old 10-04-2011, 11:31 AM
The Grumpiest
grumblemarc's Avatar
Waste of time and money? Yes. You'll still be sloooooow.
grumblemarc is offline
Old 10-04-2011, 01:46 PM
Master Detailer
98civdx's Avatar
Originally Posted by rulemaker
Are you fast with your turboed d16y8? I don't think so! D16y7's pistons have a higher compression than the y8's. D16Y7 with mini me swap runs better than D16Y8.
Your wrong.
D16y8 has 9.6:1
D16y7 has 9.4:1
98civdx is offline
Old 10-04-2011, 04:19 PM
so what do you guys think would swapping it with a y8 motor be better? my y7 has 180k on it. or put a y8 vtec head on it?
Old 10-04-2011, 04:24 PM
apexi_rsx's Avatar
swap the head.... a z6 head is more desirable. the y7 and y8 bottom ends are practically the same. as for the rulemaker a stock turbo D with 200hp on stock internals is not slow and def a mid to low 14 sec car. even my 4dr EJ ran 14.6 on rubber band 18" street tires w/ slicks def a high 13. ive seen many hit the low 13's on slicks. i have roll raced 350z's and kept up quiet a bit. when built a turbo D can deff stand its own ground with 300-350hp.
apexi_rsx is offline
Old 10-04-2011, 07:07 PM
so if i put a z6 head on my y7 what computer should i run in it? would converting it to obd 1 from obd 2 still let me pass emissions testing? i guess it's better but not sure what's the difference. i'm also looking at high comp. pistons and a skunk 2 pro s intake plenum/manifold what's a good chip to tune it all with? also would i need a different wiring harness?
Old 10-04-2011, 08:36 PM
apexi_rsx's Avatar
your best bet is to get low compression pistons and turbo... any n/a setup will not perform unless your adding nitrous. if u do any major mods u could try running a afc for tuning but its not a good set up. if u do any major mods ur going to have to run a chipped obd1 ecu and just use a obd2 ecu to run through emissions. being its a y7 in a ek a y8 would be your easiest swap because the 0bd2 ex ecu looks for a knock sensor. there are tricks around it if u look around.
Old 10-05-2011, 11:22 AM
i wanna keep it n/a for now i read up that higher compression pistons on non f/i motors is better but ill have to run it on premium to keep it from preigniting. so the z6 head doesn't have a knock sensor? i read that the z6 head has better quality of air flow on the top end than the y8 so i'd rather run a z6 head on it. would it also be good to port the z6 head?
Old 10-05-2011, 11:47 AM
wmac's Avatar
knock sensor is in the block, not the head. y7 blocks are tapped for it.
z6 head will require 1 longer head bolt.
if your going to port a head, just port the y8. it can be ported to flow better than an un-ported z6 head and you can still use your obd2 distributor.
it also has better 'quench pad' than z6 to resist 'knocking'.
wmac is offline
Old 10-05-2011, 06:27 PM
guessohw's Avatar
The mini me is a great starting point especially if your learning. Stock y7 is about 106HP and 92ish lbs of torque compared to the y8 which is 126HP and roughly 105lbs of torque. DON'T KILL ME OVER THOSE NUMBERS ITS BEEN A WHILE! All BS aside its a good starting point. All you need is the P2E ecu, vtec head, knock sensor and wire the vtec solenoid and I believe that's it. The ecu is straight plug and play and the head is simple to do just watch your tdc. I have two of those ecu's laying around if your interested in doing the swap. Ton of writ ups all over the net about this swap. As I have learned on here at the end of the day what you want to do and what your wallet can afford. Good luck
guessohw is offline
Old 10-05-2011, 06:40 PM
Master Detailer
98civdx's Avatar
^IACV 3 wire to 2.
98civdx is offline
Old 10-05-2011, 06:42 PM
guessohw's Avatar
Ah thats right. Y7 has 3 y8 2 wire.
guessohw is offline
Old 10-05-2011, 07:52 PM
i think that's the one my lx came with, not sure, did you mean p2p? any idea where i could find a 3 to 2 wiring adapter for the iacv? would my y7 computer kick a code with the y8 head? because i was thinking of using a chipped p28 ecu or would it be a better idea to just use a 98 ex ecu (p2p). you said you have some ecus laying around what would one of those run me? jw......sorry lot of questions i dont know much about swaps and dont wanna rush into anything till i know what will work well thanks for all the help!
Old 10-06-2011, 08:05 AM
The Grumpiest
Doing this may increase your horsepower somewhat BUT with long geared transmissions it'll be like pulling teeth getting there. You won't be taking advantage of the little bump in HP and you'll be unsatisfied.
Old 10-06-2011, 08:58 AM
apexi_rsx's Avatar
as he said long gearing will be pulling teeth to feel that little gain in hp. everyone will tell u a ex manual transmission is the best mod any d series owner can do. y8 vtec is nothing like a k20a2/z1 or b18c where when vtec kicks in u feel the pull the y8 is very faint(more bark then bite)
Old 10-07-2011, 06:57 AM
yeah I've been looking to get a different transmission my second gear syncro is bad so anytime i go for second quickly it grinds then pops in. i'm looking at one for 375 on ebay and jw i want to cam it too whats a good one to look for?
Old 10-07-2011, 12:02 PM
The Grumpiest
Don't. Adding a cam won't do dick without a tune.
Old 07-18-2019, 02:25 AM
Shawn Green1's Avatar
Hey I have a 98block with a 2000 head what ecu do I use for this setup both Honda civic ex coupe
Shawn Green1 is offline
Old 08-12-2020, 02:58 AM
Eddie Roque's Avatar
im doing that now im puttin a y8vtech head on my d16y7.. i would need a whole y8 harness right ?
Eddie Roque is offline
908civic
03-15-2010 08:34 PM
g17
05-01-2005 09:47 PM
civic4door95
04-11-2004 08:33 PM
VitaminB20
11-21-2002 02:45 AM
mini-cRx
04-19-2002 07:09 AM
Quick Reply: d16y7 block with y8 head?
