d16y people, LOOK at your engine
Ok, I need to know one thing. Pop your hood if you have either a d16y7 or y8, look under the battery you should see a clear hose running up to the fuel filter. Is the top of the hose open or sealed closed? Anyone know the purpose of this hose? Mine is burned closed becuase of a fire I had, but i need to kow if I need to replace it with an unclosed hose.
Re: d16y people, LOOK at your engine (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">Mine is burned closed becuase of a fire I had.</TD></TR></TABLE> what the hell, fire??
cliff notes: minime first swap ever, didnt tighten fuel lines enough; heat+gas=fire.
Anywayy, is it supposed to be open or closed?
Re: (turbotime)
it has a plastic square right angle thing on the end of the plastic tube.....its is supposed to be open...its a breather...
so if its open your ok....if its burnt, then that sucks, but it should be fine...
hopefully the rest of the car is ok
Re: (pornstarSR)
Ok I opened the line but it didnt fix my problem. For some reason the car hesitates throughout the rpm range.
ideas?
ideas?
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">Ok I opened the line but it didnt fix my problem. For some reason the car hesitates throughout the rpm range.
ideas?</TD></TR></TABLE>
well im gona have to say that if it didnt fix your problem...then thats not it....ts just a breather if its the same thing im talking about...
if it hesitates threw the entire rpm range and you had a fire in the engine compartment i would start checking wires....make sure your engine harness is entact and there isnt anything that is destroyed.
thats my idea for you
yeah the wires are fine, it burnt like 6 wires that i ran for vtec and such, but i reqired it with new wires. There are too manyt hings that could cause this so im just gonna take it to the shop monday.
D16SohcVtec
06-27-2008 07:01 AM
