d16a1 specs? - Honda-Tech
d16a1 specs?
Old 03-24-2009, 09:06 PM   #1
Default d16a1 specs?
i cant seem to find any definite specs on this engine. i can get one for 75$ and im just seeing if its worht buying. thanks in advance, please help...
dame-ningen is offline   Reply With Quote
Old 03-24-2009, 09:32 PM   #2
newtron63h's Avatar
Default Re: d16a1 specs?
113hp@6250 99tq@5500 9.5:1
newtron63h is offline   Reply With Quote
Old 03-24-2009, 10:04 PM   #3
New User
RedNuckles9's Avatar
what kinda vehicle you putting the possible d16a1? My 89 integra comes with it stock its a tourqe monster i love it
D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Valvetrain : DOHC (? valves per cylinder)
Fuel Control : OBD-0 MPFI
1986-1987
Compression : 9.3:1
Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
Piston Code: PG6
1988-1989
Compression : 9.5: 1
Power : 118 hp (88.0 kW, 120 ps) @ 6250 rpm
Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
Piston Code: P29 (Equivalent to PM7)
info from wikipedia
RedNuckles9 is offline   Reply With Quote
Old 03-24-2009, 10:21 PM   #4
newtron63h's Avatar
what about 99 or 101ft/lbs is a monster? im pretty sure that puts it in the kitten range. my 86 Jetta turbodiesel made 92ft/lbs, it certainly was not a monster. it just made more racket doing it.
Old 03-24-2009, 10:48 PM   #5
New User
so tourqe monster is overdoing it but a 20 year old engine with no power adders laying down a little rubber does fine by me
Old 03-24-2009, 10:53 PM   #6
newtron63h's Avatar
ok, just making sure
Old 03-24-2009, 11:27 PM   #7
cool thanks alot
so its worth the 75 bucks?
can i put a single cam vtec head on it?
Old 03-24-2009, 11:45 PM   #8
en00be's Avatar
Quote:
lol
kitten range
en00be is offline   Reply With Quote
Old 03-24-2009, 11:59 PM   #9
newtron63h's Avatar
for 75, what can it hurt.
mugen m7 torque specs. -jacob- Wheel and Tire 4 03-23-2007 08:41 AM
flywheel torque spec?? team 15 Honda Civic / Del Sol (1992 - 2000) 1 03-15-2007 10:19 AM
i need the torque specs for arp head studs and the torque specs for the main bolts h22_crx Honda Prelude 0 04-18-2006 10:28 PM
Engine Specs justin 17 Tech / Misc 2 07-05-2004 08:32 AM
toda C spec install TsukubaSpec All Motor / Naturally Aspirated 5 04-22-2004 09:42 PM
Tags
19861987, 90, acura, civic, d16a1, d16a1specs, dohc, engine, head, honda, integra, sale, specs, torque, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
