Is D16A crank (jdm) same as D16z6 crank?
ok i have a D16A i need some info from a person who KNOWS not someone who thinks they know
i need to know if the D16A crank (jdm) is the same as a D16z6 crank journals/ and so on if u can post me a link with the Tech data would be great thanks for help honda tech
i did look and found a few threads but nothing that can prove to me that z6 and a d16A are the same bottom end
Re: Is D16A crank (jdm) same as D16z6 crank?
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
basically you need to know if you can use a D16A crank in a D16z6.
Honestly, I have never heard of a D16A. I will assume however that they are interchangeable since all D series of that style or whatever are the same bore. So strokes will be the same. If the D16A was equivilent to a D16A6 or such, it should be compatible. The only way to know for sure is to take it out and mic the journals. I'm sure data exists for the D16Z6 so you don't have to tear both apart.
excuse my spelling and maybe not sounding totally coherant, work sucked so I've been drinking.
hyboost
09-10-2010 07:06 PM
