D16 manifold on a D15 engine
Old 06-21-2010, 08:25 AM
smirnofff's Avatar
Default D16 manifold on a D15 engine
Hello,
is it Posible to put an D16 from a Vtec engine Manifold on a D15 (1.5 Dxi) engine?.
Regards.
Old 06-21-2010, 08:34 AM
Gunmetal_B20_Hatch's Avatar
Default Re: D16 manifold on a D15 engine
Originally Posted by smirnofff
Hello,
Regards.
Intake or exhaust?
Either way, yes you can but it may require some wiring depending upon the year model of the parts.
Old 06-21-2010, 08:38 AM
smirnofff's Avatar
sorry forgot, I'm talking about the Intake manifold,
from a Civic Ex 94 D16 Vtec
to Civic DXi 93 D15
what changes will it reqire?.
Old 06-21-2010, 08:40 AM
smirnofff's Avatar
is the Gasket on D16 and D15 the Same?.
thanks.
Old 06-21-2010, 08:44 AM
Icon7 Re: D16 manifold on a D15 engine
thanks.
Everything should be the same. Only difference may be the location of the MAP sensor.
Old 06-21-2010, 08:48 AM
smirnofff's Avatar
so it's just a "Plug n Play"?,
is the map sensor location is a problem?,
Old 06-21-2010, 08:49 AM
It should be plug & play.
The map sensor wires might need to be extended, but maybe not.
Old 06-21-2010, 08:52 AM
smirnofff's Avatar
thanks you very much
Old 06-21-2010, 09:27 AM
95musubi's Avatar
i thought they wont work? i thought because the head is different?
Old 06-21-2010, 10:03 AM
smirnofff's Avatar
what do you mean?.
Old 06-21-2010, 10:43 AM
apexi_rsx's Avatar
the manifold should work but just make sure where the coolant that runs through the manifold into the head isnt leaking. sometimes they are different shapes and end up leaking. you cant put a z6 manifold on a y8 . but im using a y8 manifold on my z6 and its fine.
Old 06-21-2010, 11:29 AM
smirnofff's Avatar
are there should be more ajustments besides the "plug N play" ?.
or just to remove the old one and put the D16 new ?.
any elctronic\pc ajustments? .
is it whort the work ? ,
what are the throttle sizes on those 2? .
civic DXi 93 Hatch (D15b7? -- not sure)
D16Z9 vtec.
teler86
01-11-2006 01:51 PM
88 rex
08-16-2005 06:49 PM
ftwlucky13
02-02-2005 10:33 PM
jdmsiR20
11-12-2003 06:18 PM
Quick Reply: D16 manifold on a D15 engine
