D16 head on D15 Block - Honda-Tech
Old 05-29-2009, 12:26 PM   #1
hammergunner's Avatar
Default D16 head on D15 Block
The title is pretty much the question at hand
will a d16 vrec head fit on a d15 block with no modification or do i need to run the vtec oil lines like on the B series dohc motors?
any and all info about this will help greatly.
Thanks for helping out.
hammergunner is offline   Reply With Quote
Old 05-29-2009, 12:51 PM   #2
I'm not Rick!
rick_rabies's Avatar
Default Re: D16 head on D15 Block
it fits. its called a minime. no oil lines. take out the oiler in the block when you put the head on and you need to use the d16 timing belt, dizzy and all its atachments. you should get a z6 or y8 intake mani for it. iv never heard of vrec....
rick_rabies is offline   Reply With Quote
Old 05-29-2009, 01:02 PM   #3
vrec?
and whats the oiler (oil dowels?) main oil feed in the oil pan?
Please be more informative
thanks for the other info though. Big help
Old 05-29-2009, 01:13 PM   #4
new information ---- The guy who i'm buying the motor from missread the code
its a d16 non vtec block
and i have the d16 vtec head
Bolt right up or need modification?
Old 05-29-2009, 01:22 PM   #5
New User
i have a d16z6 vtec for sale.100k.no oil leaks.+new altenator,water pump 1k,trans,
axels 10k,ecm fuel rod,ect.....realized i want a gsr?????u r kinda far???anybody
J ROD is offline   Reply With Quote
Old 05-29-2009, 01:23 PM   #6
New User
$700
Old 05-29-2009, 01:24 PM   #7
JosephColy's Avatar
i take it its a D16Y7 block and a Y8 head?
JosephColy is offline   Reply With Quote
Old 05-29-2009, 01:27 PM   #8
I'm not Rick!
700 can get you a gsr block or ls motor and tranny in some places.
but on the block in the dowel pin areas there is a thingy pressed in a hole. take it out, it gets oil to the top now that you need more oil up there, no need to switch timing belts then. just put it on and wire vtec
Old 05-29-2009, 01:48 PM   #9
PLEASE STAY ON TOPIC THIS IS NOT A FOR SALE THREAD IF YOU MISS POST AGAIN YOU WILL BE REPORTED
Old 05-29-2009, 05:08 PM   #10
boost and bass's Avatar
I would just buy a d16z6, d15b, or d16y8 there easy to find very cheap and it will be more reliable and much easier to do
boost and bass is offline   Reply With Quote
Old 05-29-2009, 09:23 PM   #11
Jimster480's Avatar
just get the D16 Block and the head. There is no such thing as a non-vtec block. No Blocks have vtec. vtec is all in the head. So yes it will completely bolt up with no problems, and make a D16 VTEC motor. Now depending on the D16 Block it will yeild different amounts of power. And have a different compression ratio. What is the code on the D16 Block?
Jimster480 is offline   Reply With Quote
Old 05-30-2009, 01:41 AM   #12
sLAg's Avatar
would a minime swap pass smog in cali ?
sLAg is offline   Reply With Quote
d16 block/d15b head help?? wagoslam Honda CRX / EF Civic (1988 - 1991) 4 06-30-2015 05:21 AM
Head swap Perrdog Honda Civic / Del Sol (1992 - 2000) 12 04-25-2013 10:43 AM
D15B block, D16z6 head, will the z6 tranny bolt up? SpeedRacer420 Honda Civic / Del Sol (1992 - 2000) 6 09-12-2010 05:57 PM
different head for my d15a3 block illogic65 Honda CRX / EF Civic (1988 - 1991) 1 12-12-2004 05:30 PM
D15 head on d16 block? elgs Tech / Misc 3 05-12-2004 01:48 PM
Tags
block, civic, d15, d15b, d16, dowel, engine, fit, fl, head, leak, miami, oil, pins, swap, y8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
